Change IP Address
jockwav
Change IP Address
Just curious,is it possible to change your IP or not. Smiley
https://www.flickr.com/photos/james_bingham/
davidwalker900
Re: Change IP Address
that depends on if it is static or dynamic ip on sign up if is is dynamic you can just turn off your modem and back on again or if it is from a router turn off and back on again
jockwav
I think it is a static.
davidwalker900
you have to ask plusnet to do it for you if it is static ip
jockwav
Ok thanks for that.Smiley
Hi jockwav,
Can't see a static IP address on your account (assuming it's that one you're talking about)? As such just dropping the PPP session (disconnecting via the router's interface) then reconnecting should get you a different IP.
jockwav
Ok thanks Matt,i have borrowed another router to try so might do that.
Fixes: 4
Quote from: jockwav
Why would you want to do that anyway ?,  it's not like needing to change a phone number which receives excessive unwanted calls.
jockwav
Curiosity Grin
Fixes: 17
Quote from: purleigh
It might be a bit like that if your firewall were receiving excessive unwanted packets.
Fixes: 4
Correctly setting the Plusnet Broadband Firewall should minimize that potential problem, for most customers.
