Change IP Address
- Change IP Address
Change IP Address
08-11-2013 1:14 PM
Re: Change IP Address
08-11-2013 1:17 PM
08-11-2013 1:22 PM
08-11-2013 1:23 PM
08-11-2013 1:24 PM
08-11-2013 1:26 PM
Can't see a static IP address on your account (assuming it's that one you're talking about)? As such just dropping the PPP session (disconnecting via the router's interface) then reconnecting should get you a different IP.
08-11-2013 1:28 PM
08-11-2013 3:25 PM
Quote from: jockwav Just curious,is it possible to change your IP or not.
Why would you want to do that anyway ?, it's not like needing to change a phone number which receives excessive unwanted calls.
09-11-2013 5:08 PM
09-11-2013 6:04 PM
Quote from: purleigh it's not like needing to change a phone number which receives excessive unwanted calls.
It might be a bit like that if your firewall were receiving excessive unwanted packets.
09-11-2013 7:55 PM
