Case sensitivity of email addresses
- Case sensitivity of email addresses
17-01-2009 10:25 AM
This didn't happen to me but I thought I would flag it up.
As I understand the email system generally the system ignores upper and lower case differences so an email to fred@username.plus.com is treated the same as FrEd@username.plus.com
However setting Outlook Express login to username+FrEd fails whereas username+fred works.
From the help system
This lower case limitation appears to apply to the mailbox name after the username. Is this correct and if so why do we have this limitation and second I haven't found the restriction on mailbox name documented.
Quote Enter your PlusNet username and password. Important Your username will be all lowercase letters, your password is case sensitive.
Message 1 of 6
(1,426 Views)
5 REPLIES 5
Re: Case sensitivity of email addresses
17-01-2009 2:05 PM
I think it treats them the same As web site addresses, it not peculiar to OE, Thunderbird does the same, it just the way that PN set up there User and Password. Strange that the new Thompson routers WAP is all upper case
Message 2 of 6
(595 Views)
21-01-2009 12:26 PM
Quote from: Oldjim From the help system This lower case limitation appears to apply to the mailbox name after the username. Is this correct and if so why do we have this limitation and second I haven't found the restriction on mailbox name documented.
It's not unusual for a username to be case sensitive. Surely you've just quoted where it's documented? After all, from a mailbox perspective 'account username+mailbox name' *is* your mailbox username (if that makes sense!).
Configuring the actual email address in your Outlook Express account settings to use upper and lowercase letters shouldn't make a difference.
Message 3 of 6
(595 Views)
21-01-2009 4:30 PM
Bob,
I didn't make myself clear so I just tried to create a new mailbox Fred@username (note the capital) and it wasn't accepted with the error message as below which doesn't mention use of upper case being not allowed although it is inferred as the password can be upper case.
My question is why can't the mailbox use upper case
Username removed - thanks jelv
Message 4 of 6
(595 Views)
21-01-2009 4:55 PM
Quote from: Oldjim which doesn't mention use of upper case being not allowed
On the other hand it does not say that upper case is allowed
Quote letters (a-z)
Because of mixed (Windows/unix) systems that are used with e-mail its best to keep things lower case, as Windows system tend to be case insensitive and unix case sensitive.
Message 5 of 6
(595 Views)
21-01-2009 4:58 PM
Plus if you look carefully it says username (a-z) Password (a-z)(A-Z)
Message 6 of 6
(595 Views)
