Capped upload speed on 21CN
- Capped upload speed on 21CN
09-03-2011 10:22 AM
There is a totally separate option to have significantly faster upload, Annex M which does steal frequencies from download:
[quote=http://en.wikipedia.org/wiki/ITU_G.992.5_Annex_M]Annex M is an optional specification in ITU-T recommendations G.992.3 (ADSL2) and G.992.5 (ADSL2+), also referred to as ADSL2 M and ADSL2+ M. This specification extends the capability of commonly deployed Annex A by more than doubling the number of upstream bits. The data rates can be as high as 12 or 24 Mbit/s downstream and 3 Mbit/s upstream depending on the distance from the DSLAM to the customer's premises.
The main difference between this specification and Annex A is that the upstream/downstream frequency split has been shifted from 138 kHz up to 276 kHz (as in Annex J), allowing upstream bandwidth to be increased from 1.4 Mbit/s to 3.3 Mbit/s, with a corresponding decrease in download bandwidth.
I'm wondering if there is confusion about the download being reduced because that is what happens on Annex M, on Annex A there is no reallocation of frequencies when the upload is uncapped.
Has anyone actually seen a reduction in download speed when their upload was uncapped?
Re: Capped upload speed on 21CN
09-03-2011 11:01 AM
09-03-2011 12:10 PM
09-03-2011 12:18 PM
Edit: I'd like to see a bits/tone graph before and after uncapping.
09-03-2011 12:46 PM
09-03-2011 1:27 PM
09-03-2011 1:54 PM
09-03-2011 2:04 PM
Quote from: Ben We supply ADSL2+ with a 448kbps due to the significantly lower fault rate. We can uncap your upload without issue, just raise a ticket.
09-03-2011 2:11 PM
Can anyone post details of faults they have encountered as a result of asking for their upstream to be uncapped?
09-03-2011 2:14 PM
Quote from: spraxyt Plusnet posted the following explanation for initially capping the upload speed at 448kbps
But as I pointed out before on another thread how have PN come up with that conclusion when all conversions are capped by default and from the original trial I can't recall having uncapped upstream was a problem.
I believe that by default BT uncapped the upstream, at least they do for Openreach employees who as like all BT employees get their BB free.
09-03-2011 4:32 PM
10-03-2011 12:15 PM
I've just been talking to Dave about this. He explains that if we maxed out both the upstream and downstream it was more likely that instability could occur. As to it affecting the downstream rate we saw that downstream rates were compromised when there were significant errors on the upstream, so, on the whole it seemed more sensible to provision all with capped upstream with the option to uncap if requested. My own personal opinion is that the majority of users never need greater upstream speed and with that in mind it was probably a sensible decision for the business to reduce unnecessary fault reports. It would be different if we didn't allow uncapping by request but as we do I don't think it's a big deal to request it if you want it.
Jojo
10-03-2011 12:25 PM
Going on from that when someone asks about uncapping the first question should be how many upstream errors is your router logging at present. If it's significant uncapping may be inadvisable.
10-03-2011 12:35 PM
Quote from: jelv Going on from that when someone asks about uncapping the first question should be how many upstream errors is your router logging at present. If it's significant uncapping may be inadvisable.
Makes sense
10-03-2011 7:15 PM
Quote from: Joanne I've just been talking to Dave about this. He explains that if we maxed out both the upstream and downstream it was more likely that instability could occur. As to it affecting the downstream rate we saw that downstream rates were compromised when there were significant errors on the upstream, so, on the whole it seemed more sensible to provision all with capped upstream with the option to uncap if requested.
Is this supposition on Dave's part or hard facts from the trial? It can't be from the trial as this was not run to test this but was more a suck and see. To support this supposition then the original trial should have been conducted using one of two methods.
Method One
2 random equal populations are selected. One population to be capped the other not capped. Then monitor reported connection faults.
Method Two
Place everyone on a capped speed for x number of weeks then uncap them and monitor for an increase in reported faults.
These methods would back up the supposition but what we don't know if the conclusion was reached on a few connections that had underlying problems.
All what I can say looking at my uncapped and currently very unstable connection (21+ disconnects today) that I see very few upstream errors 0 FEC 7 CRC but downstream errors are in the 10,000's.
