Capped at 5mb?
Visage
Capped at 5mb?
Hi, I used to get a steady 6.5 on my ADSL line now it straggles to get above 4.7, I have a Billion modem and no matter on how low I take the SNR it doesn't appear to make any difference to my download speed, has a cap been put on the line?
1 REPLY
Fixes: 162
Re: Capped at 5mb?
Your sync speed had dropped to 5735 between the 3rd and 5th, causing a profile of 5000. Since then it's increased again to a profile of 6600.
 Chris Parr
 Plusnet Staff
