Capped/Slow internet ????
- Capped/Slow internet ????
26-06-2011 10:44 AM
Ive been using plus.net for a year now and i have been getting constant 7-8mbps internet.
However in the last 4-5 days all of sudden my internet seems to have been capped during non-free-usage times, I wouldnt even mind if it dropped by 1-2mbps (i would really) but it seems to have dropped to a staggering 0-2mbps. Did i miss something?
As of writing this post (10:42am) here is my testmy.net result
http://testmy.net/db/IYkzHKo
and this is what bt speed tester is telling me
Download speedachieved during the test was - 2101 Kbps
Additional Information:
Your DSL Connection Rate :8064 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
Its come to the point where its been faster to tether my internet using my HTC Desire with 3-4mbps rate internet
ADSL line status
Connection Information
Line state Connected
Connection time 0 days, 20:15:49
Downstream 8,064 Kbps
Upstream 448 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Modulation G.992.1 Annex A
Latency type Interleaved
Noise margin (Down/Up) 8.0 dB / 23.0 dB
Line attenuation (Down/Up) 30.2 dB / 16.5 dB
Output power (Down/Up) 12.8 dBm / 1.7 dBm
ADSL line status
Upstream 448 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Message 1 of 9
(10,004 Views)
8 REPLIES 8
Re: Capped/Slow internet ????
26-06-2011 12:20 PM
What does Current line speed say on the website here - 2500kbps? That value might have dropped due to a low sync speed event and should increase again automatically within a few hours now your BT IP Profile has recovered.
David
Message 2 of 9
(982 Views)
26-06-2011 2:29 PM
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
6.5 Mb
The net has speeded up a bit so far.
Download speedachieved during the test was - 2144 Kbps
http://testmy.net/db/8kh2Bjw
Current line speed:
6.5 Mb
Message 3 of 9
(982 Views)
26-06-2011 9:30 PM
You could try gateway hopping - disconnect from Plusnet using your router's web interface, then connect again. Note that this is *not* a router restart so sync with the exchange should not be lost.
David
Message 4 of 9
(982 Views)
27-06-2011 3:03 PM
Hi zMastaa,
Those results are quite low. There a few a few common causes for such a thing. If you ran this test wirelessly this may have affected it. AV/firewall can also slow things down. Other programs/applications/updates/computers running at the same time. Have you tried a different router? If you are running it wired have you tried a different ethernet cable?
Jojo
Jojo
Message 5 of 9
(982 Views)
27-06-2011 10:59 PM
I get what you are saying, but my internet is 100% fine after 12:00am at night, i dont see how the change of equipment should be effecting this.
Either way yes i have tried a different modem, ethernet, computer/laptop, RJ-11 cable
tried this.
Now at 22:56 bt speed tester gives me these results
Download speedachieved during the test was - 6328 Kbps
and testmy.net
Validation Link:: http://testmy.net/db/m50AtMi
dick:quote
Quote from: spraxyt You could try gateway hopping - disconnect from Plusnet using your router's web interface, then connect again. Note that this is *not* a router restart so sync with the exchange should not be lost.
tried this.
and testmy.net
dick:quote
Message 6 of 9
(982 Views)
28-06-2011 11:42 AM
HI zMastaa,
normally, if we see drops in speed at certain times of day it would be peak times that suffer. I'd be interested to see what the faults team make of it.
Jojo
Jojo
Message 7 of 9
(982 Views)
05-07-2011 10:27 PM
This is what i've been getting now when i'm downloading via Usenet. The download will start at its usual speed 700-750kbps then it will quickly drop off to 120kbps again. It will randomly return to full speed for brief moments of time too.
Ive attached screnshots
Message 8 of 9
(982 Views)
06-07-2011 10:08 AM
What time of day did you do the Usenet downloads? Between 6 and 10 pm the speeds you're seeing are what I would expect on your package: http://www.plus.net/support/broadband/speed_guide/download_speeds.shtml
Message 9 of 9
(983 Views)
