Cant remember the quartlery package you offer
- Cant remember the quartlery package you offer
11-02-2008 3:29 PM
What can i do to get a faster rate?
How much would i gain by turning interleaving back on?
What other packages do you offer to improve the service.
I want to spend money so help me.
If i get a new router and use that DMT tool can i force my SNR?
Many Thanks
Chris
Re: Cant remember the quartlery package you offer
11-02-2008 3:38 PM
If I understand correctly what you are asking, then there is nothing that PN can do to give you faster speeds. The £25 a quarter will give you a faster upload, but not download. The download is restricted by the quality of your line, so you should be seeing the fastest your line can handle.
That said, it might be worth seeing what speed you can sync at while plugged into the master socket, without anything else plugged in. If your internal wiring is not the best, that may take a little bit out of it.
Turning interleave on will slow down your connection. It gets turned on to help provide stability, but one of its side effects is lower sync speed and higher pings.
Phil
11-02-2008 3:49 PM
The fact that it is 9dB at present would tend to indicate that it wasn't stable at 6dB if that is indeed the default value
11-02-2008 5:18 PM
Quote from: pjmarsh Hi Chris
Phil
Thanks guys, i hav einterleaving turned off at the moment, roughly what percentage would you say it takes off of my speed?
I would also like to pay the £25 a quarter for faster uploads, how do i go about doing that please?
11-02-2008 5:26 PM
You would need to raise a generic ticket for my attention stating that you are happy to be charged £25 to use the IPStream Max Premium service for 3 months.
Removing interleaving should cause your speeds to decrease though.
11-02-2008 9:27 PM
12-02-2008 11:30 PM
The max Premium service offers an upload speed of 832kbps and you will see speeds of around 82k/sec
12-02-2008 11:35 PM
82KBs is a little optomistic. Due to protocol overheads it will be around 70KBs
13-02-2008 12:50 AM
