Cant get onto the Thomson Router interface (Cured not solved)
pierre_pierre
I have an approx two year  old 585 router, tried to access the router interface tonight, no joy, no answer from it
192.168.1.254   nothing
Tried it on three machines, two XP and one Linux, WiFi and ethernet.
No trouble browsing, e-mail, odd other things, network , just cant access the interface  any ideas?
Will do a reboot tomorrow morning
Fixes: 92
Re: Cant get onto the Thomson Router interface
If you run ipconfig /all from a command prompt, what are the following set to for the network adapter you're using?
  IPv4 Address
  Subnet Mask
  Default Gateway
  DNS Servers
I've had this frequently on the 585 V7 & V8, the interface would stop responding after a few hours of use although you could till ping it and telnet to it.. Nothing you can do except reboot.
pierre_pierre
did as Peter said and rebooted, now no trouble
Router speeds now 448/15323  whoopy
