Cant get onto the Thomson Router interface (Cured not solved)
- Cant get onto the Thomson Router interface (Cured ...
08-09-2010 10:45 PM
I have an approx two year old 585 router, tried to access the router interface tonight, no joy, no answer from it
192.168.1.254 nothing
Tried it on three machines, two XP and one Linux, WiFi and ethernet.
No trouble browsing, e-mail, odd other things, network , just cant access the interface any ideas?
Will do a reboot tomorrow morning
Message 1 of 4
(738 Views)
3 REPLIES 3
Re: Cant get onto the Thomson Router interface
08-09-2010 10:52 PM
If you run ipconfig /all from a command prompt, what are the following set to for the network adapter you're using?
IPv4 Address
Subnet Mask
Default Gateway
DNS Servers
Message 2 of 4
(413 Views)
08-09-2010 11:23 PM
I've had this frequently on the 585 V7 & V8, the interface would stop responding after a few hours of use although you could till ping it and telnet to it.. Nothing you can do except reboot.
Message 3 of 4
(413 Views)
09-09-2010 7:50 AM
did as Peter said and rebooted, now no trouble
Router speeds now 448/15323 whoopy
Message 4 of 4
(413 Views)
