Cant access Member Section
- Cant access Member Section
08-02-2010 1:44 PM
Username & password are correct, but i cant get in
Please fix it, thanks
Message 1 of 6
(978 Views)
5 REPLIES 5
Re: Cant access Member Section
08-02-2010 1:52 PM
I just tried logging out, then logged back in again without any problem ! ?
I did this for BOTH the COMMUNITY login, AND my account MEMBERS CENTRE.
Message 2 of 6
(545 Views)
08-02-2010 1:55 PM
I cant get in at all, works fine here though
Message 3 of 6
(545 Views)
08-02-2010 2:22 PM
Hi mrmarkus,
I've just been able to log in as you fine from here, with your existing username and password - not sure what's happening. Are you getting any error messages other than username or password incorrect?
Message 4 of 6
(545 Views)
08-02-2010 2:24 PM
Nope
Just "Invalid username or password. Please try again."
Message 5 of 6
(545 Views)
08-02-2010 2:28 PM
Very odd, I've just tested from home as well as the office and it worked fine both times for me so it's not your account or our servers. Could you try deleting cookes/saved sessions and see if that makes any difference?
Message 6 of 6
(545 Views)
