Cannot ping other computers
BlueTrin
I use the TG582n, I noticed that I cannot ping other computers on the network. I can however ping the router, is the router blocking the ping packets ? Can I change this ?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Cannot ping other computers
Out of interest, what do you need to ping other computers for?
Chris Pettitt
Cloud Environments Engineer
Fixes: 156
Are you sure that there's not something on the other devices blocking your ping request?
I can ping all the machines on my network, which is using the 582 for DHCP and routing.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
BlueTrin
Possibly but I do not know what.
I am trying to get the machines to discover each other in a homegroup and access each other shares. So far I cannot get them to join the other homegroup ...
Anyone know what I should check for the reasons to not be able to ping each other.
Den1
Not a router problem, you need to enable sharing in windows networking or what ever O/S you are using.
I also have no problem in pinging other computers on my network using the TG582n.
