Cannot load launchpad.net
- Cannot load launchpad.net
18-07-2012 5:11 PM
[tt]traceroute launchpad.net
traceroute to launchpad.net (91.189.89.222), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 6.211 ms 6.691 ms 8.176 ms
2 lo0-central10.ptn-ag04.plus.net (195.166.128.193) 28.741 ms 33.118 ms 36.691 ms
3 84.93.248.244.broadband.plus.dyn.plus.net (84.93.248.244) 30.354 ms 33.633 ms 36.164 ms
4 44.core.plus.net (212.159.1.44) 37.511 ms 38.374 ms 39.333 ms
5 te-4-2.car5.London1.Level3.net (217.163.45.249) 40.234 ms 40.641 ms 42.530 ms
6 ae-2-52.edge4.London1.Level3.net (4.69.139.106) 44.589 ms 39.141 ms 40.574 ms
7 MNET-INTERN.edge4.London1.Level3.net (212.113.14.19
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
[/tt]
http://www.downforeveryoneorjustme.com/launchpad.net says it's up and it loads via a web proxy so I guess I can blame plusnet or Level 3.
Re: Cannot load launchpad.net
18-07-2012 5:16 PM
Tracing route to launchpad.net [91.189.89.223]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 37 ms 34 ms 33 ms lo0-central10.ptw-ag01.plus.net [195.166.128.195]
3 33 ms 36 ms 32 ms 84.93.248.14.broadband.plus.dyn.plus.net [84.93.248.14]
4 32 ms 32 ms 32 ms xe-0-2-0.ptw-cr02.plus.net [212.159.1.18]
5 33 ms 32 ms 32 ms ae1.pcl-cr02.plus.net [195.166.129.3]
6 33 ms 32 ms 32 ms ae2.pcl-cr01.plus.net [195.166.129.6]
7 32 ms 33 ms 33 ms xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
8 32 ms 33 ms 33 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
9 33 ms 33 ms 33 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
10 33 ms 38 ms 33 ms ae-59-114.csw1.London1.Level3.net [4.69.153.126]
11 33 ms 40 ms 32 ms ae-1-51.edge4.London1.Level3.net [4.69.139.74]
12 33 ms 33 ms 32 ms MNET-INTERN.edge4.London1.Level3.net [212.113.14.198]
13 33 ms 33 ms 33 ms eth0.chenet.canonical.com [91.189.88.133]
14 33 ms 33 ms 32 ms launchpad-net.banana.canonical.com [91.189.89.223]
Trace complete.
18-07-2012 5:20 PM
18-07-2012 5:30 PM
1 1 ms <1 ms <1 ms RTA1335.home [192.168.1.1]
2 41 ms 51 ms 38 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 42 ms 40 ms 41 ms 84.93.249.80.broadband.plus.dyn.plus.net [84.93.249.80]
4 36 ms 39 ms 40 ms pte-sw4.plus.net [212.159.1.4]
5 37 ms 40 ms 39 ms xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
6 41 ms 39 ms 39 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
7 39 ms 39 ms 39 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
8 38 ms 44 ms 49 ms ae-59-114.csw1.London1.Level3.net [4.69.153.126]
9 37 ms 46 ms 37 ms ae-1-51.edge4.London1.Level3.net [4.69.139.74]
10 40 ms 39 ms 36 ms MNET-INTERN.edge4.London1.Level3.net [212.113.14.198]
11 38 ms 37 ms 40 ms eth0.chenet.canonical.com [91.189.88.133]
12 43 ms 42 ms 46 ms launchpad.net [91.189.89.222]
Trace complete.
ejs ptn-ag04 was the one that seemed to fall over at 0200, perhaps its still got a problem?
18-07-2012 5:35 PM
Using the Level3 looking glass, Level3 is able to route the data back ok, which was not unexpected given your traces.
http://lookingglass.level3.net/ (you need to use London, not London 2)
Canonical use three peers, including Level3.
http://bgp.he.net/AS41231
Unfortunately I cannot see the other looking glass pages to see what would occur if they were used as a return path.
18-07-2012 5:37 PM
launchpad.net is now accessible, although this forum still seems very slow.
NB: It didn't even reconnect the first time, failing with:
[tt]Remote message: address allocation failure, insufficient resources
CHAP authentication failed
Connection terminated.[/tt]
Edit: and I do have a 91.*.*.* IP address now.
18-07-2012 5:47 PM
I guess the data transfer issues are not fixed!
19-07-2012 1:16 PM
19-07-2012 6:49 PM
