Cannot load launchpad.net
- Re: Cannot load launchpad.net
18-07-2012 5:11 PM
Attempting to access http://launchpad.net is just timing out
[tt]traceroute launchpad.net
traceroute to launchpad.net (91.189.89.222), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 6.211 ms 6.691 ms 8.176 ms
2 lo0-central10.ptn-ag04.plus.net (195.166.128.193) 28.741 ms 33.118 ms 36.691 ms
3 84.93.248.244.broadband.plus.dyn.plus.net (84.93.248.244) 30.354 ms 33.633 ms 36.164 ms
4 44.core.plus.net (212.159.1.44) 37.511 ms 38.374 ms 39.333 ms
5 te-4-2.car5.London1.Level3.net (217.163.45.249) 40.234 ms 40.641 ms 42.530 ms
6 ae-2-52.edge4.London1.Level3.net (4.69.139.106) 44.589 ms 39.141 ms 40.574 ms
7 MNET-INTERN.edge4.London1.Level3.net (212.113.14.198) 42.485 ms 23.138 ms 25.125 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
[/tt]
http://www.downforeveryoneorjustme.com/launchpad.net says it's up and it loads via a web proxy so I guess I can blame plusnet or Level 3.
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
[/tt]
Message 1 of 9
(1,735 Views)
8 REPLIES 8
18-07-2012 5:16 PM
No problem here
Tracing route to launchpad.net [91.189.89.223]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 37 ms 34 ms 33 ms lo0-central10.ptw-ag01.plus.net [195.166.128.195]
3 33 ms 36 ms 32 ms 84.93.248.14.broadband.plus.dyn.plus.net [84.93.248.14]
4 32 ms 32 ms 32 ms xe-0-2-0.ptw-cr02.plus.net [212.159.1.18]
5 33 ms 32 ms 32 ms ae1.pcl-cr02.plus.net [195.166.129.3]
6 33 ms 32 ms 32 ms ae2.pcl-cr01.plus.net [195.166.129.6]
7 32 ms 33 ms 33 ms xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
8 32 ms 33 ms 33 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
9 33 ms 33 ms 33 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
10 33 ms 38 ms 33 ms ae-59-114.csw1.London1.Level3.net [4.69.153.126]
11 33 ms 40 ms 32 ms ae-1-51.edge4.London1.Level3.net [4.69.139.74]
12 33 ms 33 ms 32 ms MNET-INTERN.edge4.London1.Level3.net [212.113.14.198]
13 33 ms 33 ms 33 ms eth0.chenet.canonical.com [91.189.88.133]
14 33 ms 33 ms 32 ms launchpad-net.banana.canonical.com [91.189.89.223]
Trace complete.
Trace complete.
Message 2 of 9
(835 Views)
18-07-2012 5:20 PM
Same problem (for me at least) with http://www.ubuntu.com, not surprisingly.
Message 3 of 9
(835 Views)
18-07-2012 5:30 PM
Tracing route to launchpad.net [91.189.89.222]
1 1 ms <1 ms <1 ms RTA1335.home [192.168.1.1]
2 41 ms 51 ms 38 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 42 ms 40 ms 41 ms 84.93.249.80.broadband.plus.dyn.plus.net [84.93.249.80]
4 36 ms 39 ms 40 ms pte-sw4.plus.net [212.159.1.4]
5 37 ms 40 ms 39 ms xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
6 41 ms 39 ms 39 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
7 39 ms 39 ms 39 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
8 38 ms 44 ms 49 ms ae-59-114.csw1.London1.Level3.net [4.69.153.126]
9 37 ms 46 ms 37 ms ae-1-51.edge4.London1.Level3.net [4.69.139.74]
10 40 ms 39 ms 36 ms MNET-INTERN.edge4.London1.Level3.net [212.113.14.198]
11 38 ms 37 ms 40 ms eth0.chenet.canonical.com [91.189.88.133]
12 43 ms 42 ms 46 ms launchpad.net [91.189.89.222]
Trace complete.
ejs ptn-ag04 was the one that seemed to fall over at 0200, perhaps its still got a problem?
Trace complete.
Message 4 of 9
(835 Views)
18-07-2012 5:35 PM
Looking deeper into this, you are both on different IP ranged. Ejs, if you reconnect to a none 91 IP address, you will likely operate OK.
Using the Level3 looking glass, Level3 is able to route the data back ok, which was not unexpected given your traces.
http://lookingglass.level3.net/ (you need to use London, not London 2)
Canonical use three peers, including Level3.
http://bgp.he.net/AS41231
Unfortunately I cannot see the other looking glass pages to see what would occur if they were used as a return path.
Message 5 of 9
(835 Views)
18-07-2012 5:37 PM
I have gateway hopped and managed to get onto pcl-ag08.
launchpad.net is now accessible, although this forum still seems very slow.
NB: It didn't even reconnect the first time, failing with:
[tt]Remote message: address allocation failure, insufficient resources
CHAP authentication failed
Connection terminated.[/tt]
Edit: and I do have a 91.*.*.* IP address now.
Message 6 of 9
(835 Views)
18-07-2012 5:47 PM
Then I appeared to lose everything except DNS resolution??? and had to reconnect again! Not sure if the IP address of everything I tried could have been cached.
I guess the data transfer issues are not fixed!
Message 7 of 9
(835 Views)
19-07-2012 1:16 PM
Unfortunately not yet, though Bob's posted an update to our service status page - you shouldn't see the issues if you get a fresh connection on there (so the above is a tad worrying) but we'll be reloading it later this afternoon which should sort things out. We'll update with details on that as soon as possible.
Message 8 of 9
(835 Views)
19-07-2012 6:49 PM
I guess it was just unlucky going from ptn-ag04 to pcl-ag08.
Message 9 of 9
(835 Views)
