Cannot connect PlusNet Router to Netgear Range Extender - Help please!
- Cannot connect PlusNet Router to Netgear Range Ext...
13-01-2015 11:27 AM
This was not a problem with my previous ISP's router and, having googled this, other people seem to have the same problem with PlusNet's router and Netgear range extenders.
Is there a fix for this/a way round it?
Grateful for any help.
Re: Cannot connect PlusNet Router to Netgear Range Extender - Help please!
13-01-2015 4:21 PM
14-01-2015 10:50 AM
14-01-2015 12:49 PM
14-01-2015 12:52 PM
14-01-2015 1:35 PM
Unfortunately, the post re. the person with a similar problem doesn't help me, as they did manage to contact Netgear, who helped them resolve the problem.
I appreciate the replies and will keep trying Netgear.
15-01-2015 1:44 AM
Can I ask the obvious and sorry if you have already done this???
Have you reset it to clear all previous settings?
If so have you followed the instructions.....
Here for the original model http://kb.netgear.com/app/answers/detail/a_id/20912
Or here if you have v2 model http://kb.netgear.com/app/answers/detail/a_id/24641
For the record I have never used this product but sometimes it pays to just get back to basics and start with a clean slate Incidently neither do I use the PN router but a Billion model.................though I have used Netgear router before that and I found it to be a reliable and robust bit of kit.
Oh, just a thought. As the extender appears to be like any other WiFi device when it comes to connecting I wonder if the Channel that the Thomson router is using is shared with too many devices and as such you are getting channel interference causing the Netgear to try to seek another router??? If you have an Android phone I recommend the "WiFi Analyser app" to detect all WiFi around you so that you can use it to guide you to the channel with the least shares..............do the analysis both at the Router location and the Extender location in case the channel the router is set to at the extender location is either/or too weak or too shared.
Best of luck and HTH to resolve the problem?
PS this is the app I use https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en_GB
15-01-2015 8:41 AM
16-02-2015 10:04 PM
Well - having had the same problem I think I've solved it. It appears that the NetGear extender doesn't like the default password that the plus net router uses (I hadn't bothered to change mine since getting plus net last year). So, don't use the automatic WPS setup as this will try to keep the same password. Instead use the Netgear setup genie (if you've already used WPS you'll need to reset the extender using the old paper clip in the tiny hole trick!).
Simply follow the setup steps and then when it gets to the point where it says "Use the same password" (or words to that effect), unstick the box and create a separate password.
And it appears to have worked! Whooppeee!
Good luck - let me know if it works for others.
S
27-02-2018 5:07 PM
I know this is very old now, but wondering if you can help. My previous router was Netgear and I have a Netgear extender which does not want to connect the the new Plusnet router. I also have Netgear Genie, but I'm not sure where or how to connect to the extender through that. Could you please provide a bit more detail?
27-02-2018 5:23 PM
