Cannot access some sites and ages on some sites
zoppz
Just moved over from SKY to Plusnet. I am using Linksys WAG54G router. Connection is stable at ~4MB but I cannot access sites and sub-section of the other. I used the same router before so I know it works.
Any idea why this might happens.
Huh  Cry
Fixes: 62
Re: Cannot access some sites and ages on some sites
which sites
zoppz
pierre_pierre
all loaded virtually immediate
Fixes: 62
is the router still using Sky DNS lookup
Try using Google DNS IP addresses 8.8.8.8 and 8.8.4.4
zoppz
I reset the router to factory default settings prior to configuring for Plusnet.
DHCP is enabled, all DNS service IP addresses are set at 0.0.0.0.
The problem sites are never completly downloaded with all the components needed. I tried 3 different machines and 3 different browsers; same issues on all with with slightly different results. For example, MS IE and Safari will not load www.GMX.com but Chrome is OK. Safari fails to www.apple.com. All fiails on https sites with logins and follow on secure pages.
IfI  leave www.gmx.com in MS IE to load it does it in ~45 minutes. It seems this a speed problem but speed tests register 320 kbps speed.
Cry
Fixes: 62
Those aren't correct Plusnet DNS servers are
212.159.13.49
212.159.13.50
212.159.6.9
212.159.6.10
zoppz
Oldjim, thanks for the prompt reply.
What are the 'WINS' and 'Static Routing' settinga for Plusnet, if they help or are needed? They are all set to 0.0.0.0 at present.
Zoppz
Fixes: 62
I have no idea but try setting the router to get the DNS servers automatically which should be on the basic adsl settings screen
zoppz
Hi Oldjim,
See attached, made these changes and hardbooted the router. No improvement.
Zoppz
Fixes: 62
Which DNS servers is your PC set to use
zoppz
The output from Ipconfig /All show:
DNS Servers: 212.159.13.49/50/9/10 and 192.168.1.1.
Also, at the top DNS Suffix Serach List: 'domain_not_set.invalid'
Fixes: 62
192.168.1.1 which is your router shouldn't be there - I think
This is what mine shows
Ethernet adapter Local Area Connection:
  Connection-specific DNS Suffix  . :
  Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
  Physical Address. . . . . . . . . : 00-1A-4D-59-68-29
  DHCP Enabled. . . . . . . . . . . : Yes
  Autoconfiguration Enabled . . . . : Yes
  Link-local IPv6 Address . . . . . : fe80::3075:bb5f:9d3d:1bc4%11(Preferred)
  IPv4 Address. . . . . . . . . . . : 192.168.0.5(Preferred)
  Subnet Mask . . . . . . . . . . . : 255.255.255.0
  Lease Obtained. . . . . . . . . . : 22 November 2010 17:59:04
  Lease Expires . . . . . . . . . . : 01 December 2010 09:29:29
  Default Gateway . . . . . . . . . : 192.168.0.1
  DHCP Server . . . . . . . . . . . : 192.168.0.1
  DHCPv6 IAID . . . . . . . . . . . : 234887757
  DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-72-15-1D-00-1A-4D-59-68-29
  DNS Servers . . . . . . . . . . . : 8.8.8.8
                                      212.159.13.50
Fixes: 24
The results from ipconfig /all would normally just show the IP address of your router under DNS servers.  You can override this in your network adaptor settings and I presume you have done this (as Oldjim does because he doesn't trust the Plusnet DNS servers).  Why not follow the conventional route at least until we sort out your problem?
  Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
  Physical Address. . . . . . . . . : 00-23-54-C6-CE-81
  Link-local IPv6 Address . . . . . : fe80::4575:8ffe:77cc:b12f%11(Preferred)
  IPv4 Address. . . . . . . . . . . : 192.168.0.20(Preferred)
  Lease Obtained. . . . . . . . . . : 28 November 2010 19:37:07
  Lease Expires . . . . . . . . . . : 01 December 2010 19:37:06
  DHCPv6 IAID . . . . . . . . . . . : 234890068
  DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-00-0C-44-00-23-54-C6-CE-81
  DNS Servers . . . . . . . . . . . : 192.168.0.1
  NetBIOS over Tcpip. . . . . . . . : Enabled
zoppz
I set the network adapter DNS setting to 8.8.8.8 and 8.8.4.4 as suggest by Oldjim last night. The ipconfig /all output shows it being set as that. Tired the www.gmx.com, which stop at 'secureaddthis.com' and www.MSDN.com sites, same result; still loading after 20 mins. The line speed as same as yesterday, ~3.2mbps.
Large simple site like BBC and Sky load slowly but are done in 20-30secs. Can't watch youtube in higeher resolution takes forever.
Zoppz
