Cannot access iplayer
- Cannot access iplayer
21-11-2012 10:42 AM
Just connected with Plusnet, internet is working fine faster than TalkTalk but haven't been able to connect to iplayer yet keeps telling us there is an error in connecting.
Message 1 of 4
(840 Views)
3 REPLIES 3
Re: Cannot access iplayer
21-11-2012 11:09 AM
Hi there and welcome to the community forums.
Those sorts of errors are usually seen when there isn't sufficient bandwidth to try and stream, is it HD content that you're trying to play? I ask as your current line profile is 1600kbps which AFAIK could leave you struggling to stream in HD.
Message 2 of 4
(488 Views)
21-11-2012 11:21 AM
I have been trying to connect to my blueray dvd to watch a missed programme, i can watch it via my laptop, many thanks brenda
Message 3 of 4
(488 Views)
21-11-2012 12:15 PM
Hi brenda,
Does your Bluray provide any other internet enabled function, other than iPlayer?
If so, do these function at all?
Just trying to understand if this is a generic connectivity issue on the device, or iPlayer specific.
Additionally, do you connect to the router via wireless or via an Ethernet cable?
Message 4 of 4
(488 Views)
