Cannot access forums
- Cannot access forums
30-05-2013 8:47 AM
Sorry, but the administrator has blocked access from proxies. Other causes of this error include using an intranet (school connections), a cell phone, or using a browser that does not support compression or does not accept encoding'
This mainly happens on thetechgame.com
Im not on a cell phone, or on an intranet and i dont think i have a proxy on but im not sure how to check. I've also tried getting on them with firefox, chrome and internet explorer and i get the same error
Any help will be appreciated
Re: Cannot access forums
30-05-2013 9:37 AM
30-05-2013 9:42 AM
Check which Gateway you are on , and post the first part of your current IP address ie 87.115.xxx.xxx
Then Gateway hop, assuming you have the TG582n, log in to your modem/router and go to the Internet Box as shown here and click Disconnect. This drops the PPP session to Plusnet (not the sync). Wait about 30 seconds and then Click Connect.
Then check which Gateway you are on now, hopefully another, and check you have a new IP address in a different range. Check you particular forum access again, and then post the first part of that new IP address. For some reason which Plusnet may be able to get resolved, your forum isn't recognising your IP address as being a UK address belonging to Plusnet.
30-05-2013 9:43 AM
Which internet security package are you using
30-05-2013 9:50 AM
Harrison, if you don't know how to check your IP address try http://whatismyipaddress.com/
30-05-2013 9:53 AM
http://whatismyipaddress.com/proxy-check
30-05-2013 9:54 AM
30-05-2013 10:13 AM
30-05-2013 10:18 AM
Not disputing that, but which is the easiest to check first
30-05-2013 10:19 AM
30-05-2013 10:20 AM
30-05-2013 10:22 AM
Click on the "how do I disinfect" link to expand, download TSSDKiller and run it - see if it finds any nasties.
30-05-2013 10:26 AM
30-05-2013 10:27 AM
30-05-2013 10:29 AM
http://postimg.org/image/adzd27yah/
