Cannot Seed
dennisb66
Cannot Seed
I have no problem d/loading on P2P however I cannot connect to peers when seeding.I have checked Port Opening and get the following  message.......OK! Port 37378 is open and accepting connections.
You will be able to receive incoming BitTorrent connections..
Can anyone advise?
elementaltm
Re: Cannot Seed
Sound like an issue with your P2P client or perhaps the limited bandwidth available for traffic upstream... What P2P client are you trying to use?
DM.
KABOOM!
dennisb66
Re: Cannot Seed
I mainly use utorrent but it's also happening on azureus.My router firewall service setting is TCP/UDP which I understand should open both incoming and outgoing on port 37378 and 52000 respectively.
James
Re: Cannot Seed
How long has this been a problem for?  I'm seeing a fair amount of usage on P2P on your account.  Has it only just started happening?
dennisb66
Re: Cannot Seed
Hi James,yes it has only recently started happening.
James
Re: Cannot Seed
Randomness!  Can you try using a different port on uTorrent?
It's not apparently a traffic management issue as you haven't hit your usage allocation.
dennisb66
Re: Cannot Seed
OK James,will do.Thanks for all replies.
