Cannot Connect with sky Netgear DG834DT v1 after being flashed
- Cannot Connect with sky Netgear DG834DT v1 after b...
25-01-2011 10:12 AM
But I get an error on internet bars on bottom panel, its got Yellow square with exlamation mark. Its say No internet access.
Please help?
Re: Cannot Connect with sky Netgear DG834DT v1 after being flashed
25-01-2011 10:55 AM
See here -
http://www.kitz.co.uk/isp/sky_connection.htm
25-01-2011 11:51 AM
25-01-2011 12:03 PM
25-01-2011 12:16 PM
really love to sort this out.
25-01-2011 12:45 PM
25-01-2011 1:08 PM
Quote from: mannyg So do you think after flashing the router, i will be unable to use it with plusnet?
Sorry, I didn't realise you were trying to connect to Plusnet. Yes this should be OK.
See settings here -
Quote . Broadband Connection Settings
These are the settings you'll need to connect to our broadband service with a compatible router.
The terms used for these settings can vary, depending on the make and model of your router. We've included the most common alternatives below.
Connection Settings
Broadband Username/Login name username@plusdsl.net
Connection Type / Encapsulation PPPoA /PPP over ATM
Password The password you use to log in to this website
Virtual Path Identifier (VPI) 0
Virtual Channel Identifier (VCI) 38
Multiplexing method VC Based / VCMUX / VC-Multiplexing
Please note:
* The above table has everything you'll need to get connected with any ADSL compatible broadband router
* Some routers may ask you to enter other settings not mentioned above, you should be able to leave these as default or blank
* If your Plusnet broadband was activated before August 2002, your username may be username@plus.net rather than username@plusdsl.net
* Former Affinity Broadband customers will need to use username-pn@aihpipe.co.uk
26-01-2011 2:05 PM
26-01-2011 4:01 PM
Here are my settings. I do not have the same router as you but the settings are almost the same.
26-01-2011 4:27 PM
26-01-2011 4:29 PM
26-01-2011 4:38 PM
make sure it's <username>@plusdsl.net and check your password.
