Canceling earlier due to poor speed
- Canceling earlier due to poor speed
27-02-2022 2:55 PM
Re: Canceling earlier due to poor speed
27-02-2022 3:23 PM
@Dsx333 You reported a problem back in July last year. Did you do as was suggested in that topic and report a problem?
If you cancel your DD before giving Plusnet a chance to investigate, you will most likely find that the account will be passed to debt collectors.
27-02-2022 4:05 PM
From reading the history it looks like it was you who 'threw in the towel' last July by failing to come back here.
Good luck with the Debt Collectors, damaged Credit Record and complaint to Ofcom.
27-02-2022 5:24 PM
Relying on email and chat to get problems sorted is a major problem for you and will not help your case with Ofcom.
There has never been an email address to contact support and chat was disabled almost 2 years ago.
Good luck in you quest!
27-02-2022 6:06 PM - edited 27-02-2022 6:07 PM
Broadband dropping on inbound calls invariably point to a faulty filter (which you’ve changed) or a faulty line card in the exchange … investigation of which needs engineer engagement as Gandalf sought to arrange for you.
So are you now going to engage with the process?
27-02-2022 10:04 PM
Hiya @Dsx333,
I'm really sorry for the ongoing problem with your connection and for the undue stress this is causing.
I can see my colleague @Gandalf did as some question to help us narrow down some of the symptoms we were seeing but we had no response back. I can also see that a fault was raised in August and our fault team requested to send an engineer to investigate the issue further but had no response.
I can assure you that we will always endeavour to resolve faults as quickly as possible and look at a refund for any services that are unusable, having said that we do need to be given time and be allowed to go down all avenues of trying to resolve the fault.
I will have taken ownership of your complaint and I really would like to progress this to a resolution.
Please can you advised the following on the ticket here;
Have you tried an alternative micro-filter?
Can you also look at the image below and advise if the spaces where the router is dropping is anyone turning the router off?
In regards to the low speed this is because the line has been banded and the speed reduced due to drops shown in the image below. Once I can get to the source of the drops, I can advised the best step forward.
27-02-2022 10:46 PM
28-02-2022 8:12 AM
Totally agree, @Townman .Maybe if the OP had followed up on their original topic, we wouldn't be having this conversation.
