Can you nudge up my Plusnet profile please
- Re: Can you nudge up my Plusnet profile please
22-08-2012 5:09 PM
Hi folks,
my BT profile is 1.32 my PN profile is 1.1 my current modem stats are :-
Line Mode ADSL2 Line State Show Time
Line Power State L0 Line Up Time 01:04:30:13
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 1501 Kbps 659 Kbps
Noise Margin 4.4 dB 3.4 dB
Line Attenuation 65.0 dB 39.4 dB
Output Power 0.0 dBm 12.9 dBm
MSGC (number in overhead channel data) 12 12
B (number of bytes in Mux Frame) 174 82
M (number of Mux Frames in FEC Frame) 1 1
T (Mux Frames over sync bytes) 1 1
R (number of check bytes in FEC Frame) 16 12
S (ratio of FEC over PMD Frame length) 3.7087 3.9791
L (number of bits in PMD Frame) 412 191
D (interleaver depth) 8 8
Delay 7 msec 7 msec
Super Frames 6148417 6148415
Super Frame Errors 14198 0
RS Words 110671510 418092220
RS Correctable Errors 3557896 3216
RS Uncorrectable Errors 76492 0
HEC Errors 12715 0
OCD Errors 548 0
LCD Errors 0 0
ES Errors 0 0
Any disconnections within the last week have been as a result of me resetting the router to try and get my PN profile to increase, without much success :(.
Many thanks, Ian
Delay 7 msec 7 msec
HEC Errors 12715 0
OCD Errors 548 0
LCD Errors 0 0
ES Errors 0 0
Many thanks, Ian
Message 1 of 5
(938 Views)
4 REPLIES 4
22-08-2012 5:24 PM
Hi dvvrue95,
I adjusted your speed profile to match your IP profile. You will see your increase within the next 4 hours.
If there's anything else please let me know.
Chris
Chris
Message 2 of 5
(436 Views)
22-08-2012 7:42 PM
Hi Chris,
thanks will keep fingers crossed
Ian
Ian
Message 3 of 5
(436 Views)
23-08-2012 9:13 AM
Good Morning PN,
after that change my PN profile is now 0.9 and my BT profile is now 1.08
Obviously I didn't keep my fingers crossed enough.
Ian
Ian
Message 4 of 5
(436 Views)
23-08-2012 11:09 AM
Morning Ian,
There was a disconnection on your line at 1.45 this morning and your speed synced at a lower speed.
I have adjusted your profile again as it appears your sync speed has increased.
If it still hasn't improved, then I'd suggest trying a PPP disconnection, login to your router and click disconnect, then power down your router and leave for a few minutes and power back on. You will then need to login to your router again and click connect.
Let me know how you get on.
Chris
Chris
Message 5 of 5
(436 Views)
