Can you help?
h_milsom
Can you help?
I run an Apple Time Capsule as my wireless network, connected to a D-Link ADSL modem. Connection is via Ethernet. With this set-up I can achieve a download speed of up to 5Mb/s.
I have set up my neighbour who uses a PN wireless router. If I hook into his wireless network I can download at >6Mb/s.
Can anyone suggest what is going on? Both systems use WEP.
Any thoughts?
Kind Regards
Hugh
Fixes: 62
Re: Can you help?
Probably different sync speeds and profile speeds
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Can you help?
There could be multiple reasons for this.
- Different product with us
- Different wholesale product (20CN vs 21CN)
- Faster sync speeds and therefore IP profile
 Chris Parr
 Plusnet Staff
h_milsom
Re: Can you help?
Thanks guys! Not quite sure I understand: We're both on £5.99 packages and we are attached properties built at exactly the same time. If anything his line is longer than mine!
Could we have different sync speeds and profile speeds?
Our exchange is not 21CN until March .....
Kind Regards
Denzil
Re: Can you help?
I am in the middle of a terrace of three built on its own on the top of a hill. My phone line and number 1's apparently take a completely different route to number 3's line. So yes, it is possible for neighbours to have different line speeds.
pierre_pierre
Re: Can you help?
I have a pole outside my house, a couple of years ago they put in a few more polesup the road, the manhole is just the other side of my garden.  One cable went up the road, three detached properties, across a side road to a house, now it does at least have a prop in the middle
h_milsom
Re: Can you help?
I simply disconnect and reconnected - now speeds match my neighbour!
Problem solved.
Off to O2 - expecting great things from their LLU service.
Ciao
Hugh milsom
pierre_pierre
Re: Can you help?
strange person, what did he want?
h_milsom
Re: Can you help?
Thanks!!
pierre_pierre
Re: Can you help?
my comment was what is the reference to O2 and LLU?
h_milsom
Re: Can you help?
Hi Pierre!
Only that I've decided to try out O2 with their LLU services at my exchange. PN won't be offering up to @20M until March and will be a little more expensive so - I'll give O2 a go.
Thanks for your interest and best wishes
Hugh
PS  Not really as strange as you may think!
hjm
dick:quote
pierre_pierre
Re: Can you help?
my schedule is between 3 - 30 th march, but BT are giving end of June for the customer.  Also I am on Value at £5.99 so will not get the enhanced speed, just hope they dont put me on an ADSL2 line, happy where I am at 8128 synch
h_milsom
Re: Can you help?
Well, O2 are suggesting a speed of 17M! I live pretty close to the exchange.
We shall see. I may have made an almighty boo-boo in seeking greener grass.
If I have - then expect me back with PN with my tail between my legs!!
Regards
Hugh
dick:quote
pierre_pierre
Re: Can you help?
its hard for people on PN to say but Goodbuy Wink Wink
