Can you disconnect certain devices from the internet?
- Can you disconnect certain devices from the intern...
- « Previous
- 1
- 2
- Next »
Re: Can you disconnect certain devices from the internet?
26-05-2015 10:25 PM
the only devices shown should be the ones entered by the "wireless macacl add" command, look at it as priming this feature with devices you wish to be able to enable / disable on wifi.
26-05-2015 10:53 PM
Thanks npr and Jim for your help; really appreciated
27-05-2015 11:53 AM
Do you know what was causing it not to work, do I need to improve the instruction on the webpage?
27-05-2015 12:44 PM
And I think it was the first part of the instruction : "wireless macacl list". You have to put the mac/physical address after that command, then follow on with the rest of the code. That's obviously why it kept saying 'station not present' even though it shows up on Home Network as being 'active'.
27-05-2015 1:06 PM
Hope you think that helps.
27-05-2015 1:12 PM
27-06-2015 3:36 PM
Sorry to bump up this thread but it seems one of the laptops can't seem to access Youtube. This is after I 'allowed' it to connect back again. All other sites are fine except for that one
What's gone wrong?
27-06-2015 9:09 PM
Have you looked in the routers parental control section in the GUI?
That's the only settings in the router which I can thing of which can block a web site.
Alternatively are you using opendns and have blocked youtube with that?
27-06-2015 9:44 PM
Quote from: npr Have you looked in the routers parental control section in the GUI?That's the only settings in the router which I can thing of which can block a web site.
Had a look and there's no websites added.
Quote Alternatively are you using opendns and have blocked youtube with that?
The thing is, it's not my laptop that's having the problem. How would I be able to check if opendns was used and how to 'normalise' it ?
27-06-2015 10:03 PM
In the command window enter nslookup youtube.com -- please post the result from that.
This is my result, yours will have a different server IP.
Quote C:\Users\npr>nslookup youtube.com
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
Address: 216.58.208.78
Also can you please check the laptops date and time is correct.
27-06-2015 10:28 PM
Quote from: npr To test the dns, please open a command prompt window (window key + r then type cmd [enter])
The result below is from my laptop which is fine. Would it be different from different devices ?
Quote Server: dsldevice.lan
Address: 192.168.1.254
Addresses: 2a00:1450:4009:80d::200e
212.56.71.34
212.56.71.35
212.56.71.50
212.56.71.45
212.56.71.54
212.56.71.44
212.56.71.55
212.56.71.39
212.56.71.29
212.56.71.40
212.56.71.20
212.56.71.25
212.56.71.30
212.56.71.59
212.56.71.24
212.56.71.49
Not sure if the above is good or bad
Quote Also can you please check the laptops date and time is correct.
At the moment the laptop in question isn't with me. As soon as it is, I'll let you know if that info is correct. And how would an incorrect date/time affect a site like Youtube ? - or possibly any other ?
28-06-2015 10:10 AM
You need to test using the problem laptop, that may not be using the router for dns.
The laptops date setting is important because you say you have problems accessing a secure site. The browser needs to check the certificate for that secure site, if the laptops date is wrong the certificate may appear to be out of date.
28-06-2015 12:33 PM
And thanks for the info. re. time and date
28-06-2015 3:49 PM
That's the type of fault we could have been chasing round for ages.
- « Previous
- 1
- 2
- Next »
