Can you disconnect certain devices from the internet?
- Can you disconnect certain devices from the intern...
24-05-2015 8:21 PM
As the thread title states, is it possible to disconnect certain devices from the internet? Unfortunately when I hit 'Disconnect (from Broadband Connection), it cancels all devices.
Thanks in advance.
Re: Can you disconnect certain devices from the internet?
24-05-2015 8:33 PM
permanently or temporarily
24-05-2015 9:22 PM
Quote from: Oldjim which router
Hi Jim.
The router's the TG582. And I'd like both options of permanent and temporary if possible.
25-05-2015 9:18 AM
25-05-2015 2:39 PM
"wireless macacl list
wireless macacl modify ssid_id=0 radio_id=00:xx:xx:xx:xx:xx permission=deny" (where the 00s and x's have been replaced by the Physcial Address of the device)...
.... and it says 'station not present' when it's actually 'active' in 'Home Network'
Am I doing it wrong ?
25-05-2015 2:56 PM
The list of devices shown on the Home Network isn't actually the ones which are active only those which have been at some time
You need to telnet in again to find which ones are active
25-05-2015 4:24 PM
Could there be a problem with the instructions themselves?
25-05-2015 4:33 PM
25-05-2015 6:07 PM
25-05-2015 6:40 PM
Quote from: Cagney1994 wireless macacl modify ssid_id=0 radio_id=00:xx:xx:xx:xx:xx permission=deny
You may have just missed a bit out when copying it to the forum, but if not, it should be:
wireless macacl modify ssid_id=0 radio_id=0 hwaddr=00:xx:xx:xx:xx:xx permission=deny
npr's website says you need to do "wireless macacl add ..." first, so I suppose you could just do "wireless macacl add ... permission=deny".
26-05-2015 1:49 PM
26-05-2015 6:29 PM
wireless macacl add ssid_id=0 radio_id=0 hwaddr=00:xx:xx:xx:xx:xx permission=deny
26-05-2015 6:40 PM
Also, would the device that I need to disconnect, not be connected to the internet at the time of what I'm trying to do ?
EDIT: unfortunately it looks as if it's still connected (i.e. still showing as 'Active' in Home Network).
26-05-2015 9:50 PM
I just modified "xx:xx:xx:xx:xx:xx", in the telnet window, to the target devices mac address.
eg
Quote wireless macacl add ssid_id=0 radio_id=0 hwaddr=xx:xx:xx:xx:xx:xx permission=allow
running the following command shows the above mac ans SSID has been added to the list.
Quote wireless macacl list
Running the following command disconnects the target device from wifi and doesn't allow it the reconnect.
Quote wireless macacl modify ssid_id=0 radio_id=0 hwaddr=xx:xx:xx:xx:xx:xx permission=deny
Running the following command allows the device to reconnect to wifi.
Quote wireless macacl modify ssid_id=0 radio_id=0 hwaddr=xx:xx:xx:xx:xx:xx permission=allow
So sorry I have no idea why it's not working for Cagney1994, I can only guess the wireless devices mac address has been mistyped.
Also:
Please use the command "wireless macacl list" to see if the device has been added.
Please check ssid_id and radio_id both equal zero (=0)
Please recheck the mac address used.
Note:
Ethernet ports can also be disable if you wish to kick off a wired connected device.
http://npr.me.uk/telnet.html#eth
26-05-2015 10:13 PM
Should they all be showing ?
