Can we upgrade PlusNet Routers + Huawei modems
- Can we upgrade PlusNet Routers + Huawei modems
28-11-2013 10:53 AM
As expected, attacks on the internet connected points are coming. Is it possible to upgrade firmware on these boxes?
http://www.symantec.com/connect/blogs/linux-worm-targeting-hidden-devices
Message 1 of 5
(1,151 Views)
4 REPLIES 4
Re: Can we upgrade PlusNet Routers + Huawei modems
28-11-2013 11:00 AM
From your link
The modem isn't relevant I believe as it isn't the thing which controls network access
It is already fixed as the password is definitely not well known
Quote Upon execution, the worm generates IP addresses randomly, accesses a specific path on the machine with well-known ID and passwords
Message 2 of 5
(632 Views)
28-11-2013 12:27 PM
I think the default admin password - the serial number - is freely given away by the router over the local network by upnp, or to anyone in wifi range as part of the WPS information.
But I don't think the linked article is applicable to the technicolor routers because they don't contain php. They might have some weird server side dynamic pages, but they seem to be based on the lua programming language, not php.
Message 3 of 5
(632 Views)
28-11-2013 12:46 PM
I don't think it does as I just checked mine and the SSID is totally different from the password
Message 4 of 5
(632 Views)
28-11-2013 1:37 PM
Quote from: Oldjim The modem isn't relevant I believe as it isn't the thing which controls network access
My thought was the reverse. [ I have FTTC , so Huawei modem + Technicolour router ]
The Huawei is only addressable on an internal BT (?) network. The device you get to if you attack my IP address is the Techicolor .
I was looking to see it the Techicolor does enough logging (Appears not to) and allows flash upgarde (found command for it on telnet login, nothing on http access & no idea where I'd get a new image from in anycase)
My understanding is my IP address is tunnelled through the BT network, to attack the outside of the tunnel , one would need to start from BT private network?
Message 5 of 5
(632 Views)
