Can we do anything about the BT speedtest?
- Can we do anything about the BT speedtest?
- « Previous
- Next »
Re: Can we do anything about the BT speedtest?
11-04-2012 8:43 PM
While it might be connected to a different issue I'm experiencing: http://community.plus.net/forum/index.php/topic,103927.0.html
I thought I'd post my experience of the BT speediest from last night.
The first test I did at 22:29 showed my upload speed was higher than the upstream profile:
Is this possible?
Then an hour later, and an hour after that, both times the speedtest failed to complete, giving an HTTP Status 500 error:
(see attached for a screen shot)
There must be a better way to collect data to send to Plusnet (and BT) to help track down errors...
Quote Download speedachieved during the test was - 5.33 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.38 Mbps
Upload speed achieved during the test was - 518Kbps
Additional Information:
Upstream Rate IP profile on your line is - 448 Kbps
Is this possible?
Quote HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.IllegalStateException: Cannot forward after response has been committed
org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1078)
org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:396)
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:232)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1913)
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:462)
javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.16 logs.
Message 46 of 54
(435 Views)
13-04-2012 4:18 PM
http://test.speedtester.bt.com/
Seems to be dead for me and has been for a number of days now.
Found an alternative BT tester that "worked" but the results weren't believable. At least it gave the profile which is something, just.
Message 47 of 54
(435 Views)
13-04-2012 4:45 PM
Where did you get that url from? You should be using http://speedtester.bt.com/
Message 48 of 54
(435 Views)
13-04-2012 5:17 PM
Funny I've been using that link for over a year and until recently it always worked.
Thanks for the correct url.
Message 49 of 54
(435 Views)
13-04-2012 9:00 PM
The incorrect link restores "reasonable looking" results - it's a better link that the correct one.
Message 50 of 54
(435 Views)
14-04-2012 9:23 AM
Yes that's good its started working again.
As to where I got that link - from Kitz .
That link always seems to give more consistent and stable results.
Message 51 of 54
(435 Views)
14-04-2012 10:29 AM
I don't see how that could be given that:
C:\Users\John>nslookup test.speedtester.bt.com
Server: vnsc-lc.sys.gtei.net
Address: 4.2.2.3
Non-authoritative answer:
Address: 217.35.209.142
C:\Users\John>nslookup speedtester.bt.com
Address: 4.2.2.3
Addresses: 217.32.105.42
217.35.209.142
Message 52 of 54
(435 Views)
14-04-2012 4:50 PM
The fact that they resolve to the same IP address proves nothing, they could still be running completely different services. However, in this case, they look and behave the same to me.
Message 53 of 54
(435 Views)
15-04-2012 12:36 PM
Just noticed today that the BT Above 24Mbps Beta tester now shows upload speed test and Ping Latency figures whereas yesterday it only gave download information.
Message 54 of 54
(435 Views)
- « Previous
- Next »
