Can this be right
- Can this be right
Can this be right
14-08-2013 7:51 PM
Re: Can this be right
14-08-2013 8:00 PM
14-08-2013 8:33 PM
14-08-2013 8:52 PM
Sign up for a free router here - https://www.samknows.eu/
14-08-2013 9:57 PM
14-08-2013 10:10 PM
14-08-2013 10:43 PM
Quote from: ejs Doubtful, but we really need the stats from your router.
When I try to access my router.......IE.....http://192.168.1.254 it tells me its waiting to connect but no matter how long I wait it never connects.
15-08-2013 9:34 AM
To check, click on Start then type cmd into the search box at the bottom of the start menu. Then double click the 'command prompt' option that should be at the top of the search results, this should open a small black window with white text and a flashing cursor. Click on that, and type 'ipconfig' (without quotes) then hit enter.
Some text should pop up, you're looking for the IP address next to 'default gateway'. That'll be your router's IP, and is what you should type into the browser's address bar in order to log in to the router.
Hope that helps? Please let us know if the IP stated there is indeed 192.168.1.254
15-08-2013 2:44 PM
jim:quote
16-08-2013 10:46 PM
Unless someone can help me to get the drivers.PLEASE.
16-08-2013 11:11 PM
Quote from: robert1935 I used to build a PCs from scratch, I can water cool nearly every component, I can flash the bios till it sings, I can overclock it till its close to melt down
Regards Bob
I don't understand, how come you can't find an ethernet driver ?
The fact that you know that you need a driver suggests that you also know what driver you need.
What does Google say ?,
or even easier Windows Update > Advanced > Hardware ?,
or the ethernet card manufacturers website? ....
17-08-2013 1:18 PM
17-08-2013 2:16 PM
as it would be worth checking everything is now up to date before proceeding.
Windows Update > Advanced > Hardware updates
Quote from: robert1935 my PC has to be connected to the net by Ethernet cable, to access my router !!!!!!!!
So can you access your router now that your PC ethernet port is "all sorted" ?
17-08-2013 2:25 PM
19-08-2013 1:05 PM
