Can't view particular site
cripes
Hi folks
We have a problem accessing certain sites, and we're getting, in one case, the default CentOS Apache 2 Test page, or a 403 Forbidden error when accessing other links on the site. The site is www.abbeymachinery.com.
We have a Netgear DG834G router/modem and the Abbey site is inaccessible from any machine on the network. We can view it on the same laptop on a BT connection next door. We have tried turning off firewalls and anti virus software but no joy.
We have also tried using Google DNS or OpenDNS, but no luck either.
Any ideas or suggestions welcome!
7 REPLIES 7
agedgopher
All Star
Fixes: 15
Re: Can't view particular site
The link works fine for me using Plusnet fibre and Google Chrome.
cripes
Thanks for testing it out on your connection - wonder whether there's a configuration/network difference between fibre and  our creaky adsl connection?
Have you tried a trace route @cripes?
cripes
I can ping the site no problem, it's just that the site doesn't display.
Pettitto
Fixes: 5
What does a traceroute look like?
traceroute  www.abbeymachinery.com
cripes
Connection is on separate business premises so can't traceroute right now, I only ping via router interface remotely.
The ping returns the correct ip address of the server without delay.
Cagney1994
No problem in opening website here. I'm on standard BB using the Hub 0 router (2704n one).
