Can't upload ANYTHING
stuarteaster
Hi - I have been having serious problems in the last couple of days with uploading even the most miniscule files. Everything I'm trying has only really been less than 200KB. This has included trying to upload images to ebay which are failing. Here are some stats (that I don't understand):
Uptime: 15 days, 16:01:12
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,068 / 6,400
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,272
Data Transferred (Sent/Received) [kB/GB]: 0.00 / 3.20
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 17.5 / 29.5
SN Margin (Up/Down) [dB]: 24.0 / 6.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 131,073 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 196,612 / 0
FEC Errors (Up/Down): 7 / 218,179,325
CRC Errors (Up/Down): 10 / 1,070
HEC Errors (Up/Down): 8 / NA
Download speedachieved during the test was - 3510 Kbps
Additional Information:
Your DSL Connection Rate :6272 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
Please can you help?
Fixes: 9
Re: Can't upload ANYTHING
Do you connect to your router wired or wireless? If wireless can you try uploading with a wired connection?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
stuarteaster
Quote from: jelv
Hi Jelv, thanks for replying. I do connect by wireless but cannot plug in as my laptop does not have an ethernet port.
Fixes: 35
The most important thing from those stats is
that and line test I've just performed show that your line is connecting at good speeds both up and down and the connection is quite stable (has been up over 11 days in fact).
As jelv mentioned let us know if you've tried this via wired as wifi problems/incompatibilities  can sometimes restrict upload speeds. What else has been a problem for you apart from Ebay?
Adam
 Adam Walker
stuarteaster
Hi Adam,
Thanks. I have also been having problems uploading to a remote server, both through online uploader and FTP via FileZilla, which gives timeout errors after about 10-20kb of the file has transferred. Is there any way to diagnose problems with the wifi without plugging in as I do not have an ethernet port?
jim:quote
Fixes: 9
Can you run a speed test at http://www.speedtest.net/wave/ef680776cf64ec88 please.
Is your router one supplied by Plusnet? If so does the label underneath say it is a V8 or a V7?
stuarteaster
84ms Ping
5.16Mbps D/L
0.03Mbps U/L
Thomson router from Plusnet - V8.
dick:quote
Fixes: 9
You are another victim of the known bug with the V8 routers. You need to ask Plusnet to replace it with a V7.
Fixes: 35
We've got some in stock here in the office, just bagging one up now for you @stuarteaster
 Adam Walker
stuarteaster
Cheers guys! superb speed and customer service. Eagerly awaiting delivery.
