Can't sign in with IE7
- Can't sign in with IE7
18-10-2007 2:11 PM
What would stop me signing in with IE7 but allow, with no problems using Netscape?
Message 1 of 5
(1,606 Views)
4 REPLIES 4
Re: Can't sign in with IE7
18-10-2007 2:19 PM
Hi Stewart.
I suspect that that is probably related to this. Can I suggest that you follow the instruction on there and advise as to whether or not your problem is then fixed?
Message 2 of 5
(516 Views)
18-10-2007 2:55 PM
Cookies deleted, but still says invalid username or password?
I've gone in under Netscape and auto login was already off (although I do always use it)
Message 3 of 5
(516 Views)
18-10-2007 3:01 PM
Have you tried restarting your PC and router? Drastic I know but sometimes things like firewalls go bad with strange results such as this.
I have no problems logging in with IE7 and I've never had auto-login enabled on it (use FF mostly).
Message 4 of 5
(516 Views)
18-10-2007 4:30 PM
Switched everything off but still the same - fine with Netscape but invalid password or username with IE7
Message 5 of 5
(516 Views)
