Can't login to my router.
slavi132
So i never had this problem before the electricity stopped. After the electricity came back i can't login to my router.It just says Unable to connect to this page. My default gateway is 192.168.1.1. My router is Technicolor tg582n.
Oh and for the record my internet is now extremely slow (1mbps).Before the electricity stopped it was (8mbps). And the ping is quite high.
7 REPLIES 7
Browni
Aspiring Hero
Fixes: 60
Re: Can't login to my router.
Isn't the default gateway on one of those routers 192.168.1.254 ?
slavi132
I changed it to 192.168.1.1 a while ago.
EDIT: It still doesn't makes sense because before the electricity stopped i had good download speeds and ping and now is very bad .
Fixes: 1,600
It sounds like there’s been a power surge. Is your device you’re using connecting over WiFi to the router or via ethernet? Also do you have another router you can try?
slavi132
I'm using wifi on a laptop. I just did a speedtest and the speeds are back so there is no problem.
For now.
Fixes: 419
If you still can't log in it could be that the router has restarted and set the IP address back to 192.168.1.254. If that doesn't work then do a factory reset with a paperclip in the hole. This should return it to the default IP address from where you can set it up again from scratch
Gel
Aspiring Champion
Fixes: 29
Mav
Fixes: 515
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
