Can't get into my seedbox
Inam
Re: Can't get into my seedbox
I am running AGV on my computer however I can't access my seedbox on my IPAD as well when using plus net connection however if I change that to 3g connection then there are no issues.
avatastic
Check which gateway you're on with http://usertools.plus.net/@gateway/, log in to your router and disconnect and reconnect to the internet until you're on a different gateway.
Record the gateway you're currently on so that networking can investigate any issues if that works.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Fixes: 1,483
pcl-ag03 here and can access it no problem.
Inam
I am at work now but will try to change gateway in the moring and report back, thanks for your help chaps much appreciated.
Edit: I did actually disconnect/reboot my router today, I don't know if restart changed the gateway as I didn't check.
Inam
Manage to connect to different gateway but with mix results
Before disconnecting my router I was on PTN-AG04 and I couldn't login into my seedbox however after disconnect/reconnect I was on PCL-AG04 and I manage to login into my seedbox without issue however it only lasted 10 mins and I got disconnect since that I had 30 min success on PCL-AG04 before that stopped working again. There is definately some thing is not right on plus net side.
It has been working fine for months before this issue.
Inam
C:\Users\Home>tracert freak.seedhost.eu
Tracing route to freak.seedhost.eu [5.79.67.33]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.0.1
  2    *        *        *    Request timed out.
  3    30 ms    37 ms    28 ms  lo0-central10.pcl-ag08.plus.net [195.166.128.189
  4    23 ms    23 ms    26 ms  link-b-central10.pcl-gw02.plus.net [212.159.2.19
0]
  5    22 ms    22 ms    23 ms  xe-9-1-0.pcl-cr02.plus.net [212.159.0.222]
  6    25 ms    26 ms    26 ms  ae2.pcl-cr01.plus.net [195.166.129.6]
  7    23 ms    22 ms    23 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  8    23 ms    23 ms    23 ms  peering.thn.lon.leaseweb.net [195.66.225.56]
  9    32 ms    32 ms    31 ms  31.31.32.73
10    *        *        *    Request timed out.
11    *        *        *    Request timed out.
12    *        *        *    Request timed out.
13    *        *        *    Request timed out.
14    *        *        *    Request timed out.
15    *        *        *    Request timed out.
16    *        *        *    Request timed out.
17    *        *        *    Request timed out.
18    *        *        *    Request timed out.
19    *        *        *    Request timed out.
20    *        *        *    Request timed out.
21    *        *        *    Request timed out.
22    *        *        *    Request timed out.
23    *        *        *    Request timed out.
24    *        *        *    Request timed out.
25    *        *        *    Request timed out.
26    *        *        *    Request timed out.
27    *        *        *    Request timed out.
28    *        *        *    Request timed out.
29    *        *        *    Request timed out.
30    *        *        *    Request timed out.
Trace complete.
C:\Users\Home>
Inam
C:\Users\Home>ping seedhost.eu
Pinging seedhost.eu [85.214.229.249] with 32 bytes of data:
Reply from 85.214.229.249: bytes=32 time=48ms TTL=50
Reply from 85.214.229.249: bytes=32 time=47ms TTL=50
Ping statistics for 85.214.229.249:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 47ms, Maximum = 48ms, Average = 47ms
C:\Users\Home>ping freak.seedhost.eu
Pinging freak.seedhost.eu [5.79.67.33] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 5.79.67.33:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\Home>
Kelly
Fixes: 9
Are you sure you haven't done something daft like firewall yourself off from that server?  All the checked we've done from the customer side show ping replies, completing traces etc.
Kelly Dorset
Ex-Broadband Service Manager
Inam
As I said earlier I can't access my seedbox on my IPAD as well when using plus net connection however if I change that to 3g connection then there are no issues. Also changing gateway got me into my seedbox for 30 mins before connection stopped working again.
OshB5
Hi
Can I Just ask are you trying to access the seed box via SSH or FTP? I ask because I have had a problem for over a week now being unable to get into mine via SSH. but can get in via FTP on port 21.. Im about to try another method later today called Swish. I will let you know if it works ok or not,
Regs Osh
dragon2611
Quote from: Inam
Is it possible you're tripping some kind of security system  at the providers end, e,g tryign to make to many FTP connections, accidentally logging in with with the wrong password.
I've seen people get blocked from various servers before by having the wrong password stored in their FTP client and combined with the automatic retry on a lot of clients it can have already tripped the security system before the user notices the password was wrong.
Inam
@OshB5, can't get access via FTP or HTTP as well.
@dragon2611, Password is correct as I manage to get into my seedbox for 30 mins also checked with seedhost support and every seem to working fine on their end.
Seedhost customer support thinks there is a routing issue with plus net. It works fine on my mobile or Ipad over 3g connection but it doesn't work if I use plus net connection.
drunkenmonkey
Last login: Fri Feb 28 19:06:41 on ttys000
mbpa:~ andrewroberts$ traceroute freak.seedhost.eu
traceroute to freak.seedhost.eu (5.79.67.33), 64 hops max, 52 byte packets
1  192.168.0.1 (192.168.0.1)  1.770 ms  1.142 ms  1.995 ms
2  lo0-central10.pcl-ag04.plus.net (195.166.128.185)  20.722 ms  20.294 ms  20.261 ms
3  link-a-central10.pcl-gw01.plus.net (212.159.2.172)  20.831 ms  23.041 ms  20.659 ms
4  xe-0-2-0.pcl-cr01.plus.net (212.159.0.204)  19.592 ms  19.623 ms  19.238 ms
5  ae1.ptw-cr01.plus.net (195.166.129.0)  19.988 ms  19.740 ms  19.900 ms
6  peering.thn.lon.leaseweb.net (195.66.225.56)  21.008 ms  20.725 ms  21.813 ms
7  31.31.32.65 (31.31.32.65)  27.218 ms
    31.31.32.75 (31.31.32.75)  30.682 ms
    31.31.32.71 (31.31.32.71)  32.479 ms
8  85.17.100.115 (85.17.100.115)  29.244 ms  29.989 ms  27.707 ms
9  5.79.79.241 (5.79.79.241)  32.401 ms
    5.79.79.239 (5.79.79.239)  28.552 ms  31.859 ms
10  freak.seedhost.eu (5.79.67.33)  28.942 ms  28.028 ms  27.198 ms
Does sound like a firewall or some sort of security system issue.
Inam
Running of out of ideas now, seedhost customer support putting all the blame on plus net and plus net is telling me that there is nothing wrong on there side. Only thing left for me to try a different router now which more likely to be culprit I think.
dragon2611
I notice on the Seedhost site it says you get a VPN account with you seedbox, are you able to connect to that (Assuming it's not hosted on the seedbox itself)
