Can't get into my seedbox
- Re: Can't get into my seedbox
27-02-2014 7:38 PM
I have been told that there is plus net routing issue.
Any suggestions guys where could be the problem, any help will be much appreciated in advance.
27-02-2014 7:44 PM
Ex-Broadband Service Manager
27-02-2014 8:31 PM
1 * * * Request timed out.
2 29ms 23ms 28ms 195.166.128.192
3 23ms 23ms 23ms 212.159.2.138
4 25ms 22ms 23ms 212.159.0.110
5 23ms 22ms 22ms 195.166.129.4
6 * * * Request timed out.
7 32ms 31ms 31ms 31.31.32.67
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
Trace complete.
27-02-2014 8:49 PM
C:\Users\Kelly>tracert seedhost.eu
Tracing route to seedhost.eu [85.214.229.249]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms dsldevice.lan [192.168.1.254]
2 27 ms 26 ms 24 ms lo0-central10.ptw-ag04.plus.net [195.166.128.194]
3 29 ms 24 ms 23 ms link-a-central10.ptw-gw01.plus.net [212.159.2.156]
4 24 ms 34 ms 24 ms xe-7-2-0.ptw-cr01.plus.net [212.159.0.252]
5 25 ms 31 ms 35 ms te-4-2.car5.London1.Level3.net [217.163.45.249]
6 24 ms 25 ms 26 ms ae-52-52.csw2.London1.Level3.net [4.69.139.120]
7 23 ms 25 ms 23 ms ae-236-3612.edge5.London1.Level3.net [4.69.166.61]
8 72 ms 74 ms 73 ms Telia [4.68.111.182]
9 124 ms 64 ms 104 ms ldn-bb1-link.telia.net [80.91.246.96]
10 89 ms 89 ms 143 ms hbg-bb1-link.telia.net [213.155.137.106]
11 80 ms 84 ms 85 ms bei-b1-link.telia.net [213.155.135.215]
12 48 ms 48 ms 48 ms xe-1-3-0.core-b30.as6724.net [213.248.88.90]
13 48 ms 49 ms 48 ms te0-2-0-0.core-b2.as6724.net [85.214.0.68]
14 51 ms 168 ms 49 ms vl451.dcata-b17.as6724.net [85.214.0.175]
16 50 ms 48 ms 48 ms seedhost.eu [85.214.229.249]
Trace complete.
27-02-2014 9:40 PM
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Test-Rig>tracert seedhost.eu
1 80 ms 23 ms 99 ms 192.168.1.254
2 33 ms 31 ms 41 ms lo0-central10.pcl-ag06.plus.net [195.166.128.187
3 30 ms 32 ms 30 ms link-b-central10.pcl-gw02.plus.net [212.159.2.18
2]
4 34 ms 30 ms 33 ms xe-10-3-0.pcl-cr02.plus.net [212.159.0.214]
5 31 ms 31 ms 31 ms ae2.pcl-cr01.plus.net [195.166.129.6]
6 31 ms 30 ms 31 ms xe-11-1-0.edge3.London2.Level3.net [212.187.201.
209]
7 38 ms 37 ms 38 ms ae-3-3.ebr1.Paris1.Level3.net [4.69.141.86]
8 37 ms 38 ms 37 ms ae-81-81.csw3.Paris1.Level3.net [4.69.161.86]
9 38 ms 36 ms 38 ms ae-3-80.edge3.Paris1.Level3.net [4.69.168.134]
10 85 ms 85 ms 86 ms telia-level3.paris1.Level3.net [4.68.111.194]
11 88 ms 95 ms 85 ms prs-bb2-link.telia.net [213.155.134.226]
12 113 ms 100 ms 100 ms ffm-bb2-link.telia.net [80.91.246.180]
13 94 ms 95 ms 96 ms bei-b1-link.telia.net [80.91.254.229]
14 63 ms 63 ms 63 ms xe-1-3-0.core-b30.as6724.net [213.248.88.90]
15 62 ms 62 ms 63 ms te0-2-0-0.core-b2.as6724.net [85.214.0.68]
16 64 ms 63 ms 63 ms vl451.dcata-b17.as6724.net [85.214.0.175]
18 65 ms 63 ms 62 ms seedhost.eu [85.214.229.249]
Trace complete.
27-02-2014 9:59 PM
27-02-2014 10:04 PM
27-02-2014 10:07 PM
C:\Users\Dan>tracert freak.seedhost.eu
Tracing route to freak.seedhost.eu [5.79.67.33]
1 5 ms 6 ms 4 ms dsldevice.lan [192.168.1.254]
2 43 ms 39 ms 40 ms lo0-central10.pcl-ag08.plus.net [195.166.128.189]
3 40 ms 41 ms 39 ms link-a-central10.pcl-gw01.plus.net [212.159.2.188]
4 42 ms 38 ms 40 ms xe-9-1-0.pcl-cr01.plus.net [212.159.0.220]
5 40 ms 41 ms 42 ms ae1.ptw-cr01.plus.net [195.166.129.0]
7 51 ms 51 ms 52 ms 31.31.32.69
8 51 ms 50 ms 50 ms 85.17.100.187
9 51 ms 50 ms 50 ms 37.48.95.195
10 65 ms 50 ms 49 ms freak.seedhost.eu [5.79.67.33]
Trace complete.
27-02-2014 10:16 PM
27-02-2014 10:20 PM
27-02-2014 11:18 PM
adw@thunderbolt:~$ traceroute freak.seedhost.eu
traceroute to freak.seedhost.eu (5.79.67.33), 30 hops max, 60 byte packets
1 skynet.avatastic.co.uk (10.0.1.1) 12.531 ms 12.771 ms 13.602 ms
2 lo0-central10.pcl-ag06.plus.net (195.166.128.187) 44.043 ms 44.821 ms 45.549 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.180) 41.828 ms 42.944 ms 45.302 ms
4 xe-10-3-0.pcl-cr01.plus.net (212.159.0.212) 45.560 ms 46.093 ms 47.901 ms
5 ae1.ptw-cr01.plus.net (195.166.129.0) 49.245 ms 49.996 ms 51.906 ms
6 peering.thn.lon.leaseweb.net (195.66.225.56) 53.123 ms 30.623 ms 31.030 ms
7 31.31.32.75 (31.31.32.75) 42.633 ms 31.31.32.67 (31.31.32.67) 39.916 ms 31.31.32.65 (31.31.32.65) 33.846 ms
8 85.17.100.187 (85.17.100.187) 35.231 ms 36.018 ms 41.805 ms
9 37.48.95.195 (37.48.95.195) 41.766 ms 44.111 ms po2.cs1.ams1.leaseweb.net (37.48.95.193) 44.189 ms
10 freak.seedhost.eu (5.79.67.33) 38.852 ms 38.261 ms 37.358 ms
27-02-2014 11:28 PM
The thing is I can get into my seedbox with my 3g connection without any issues, so there must be some sort of change on plus net side.
27-02-2014 11:33 PM
If it is okay with you, I can attempt a ssh connection for you. I'll pick a username at random and dummy password and bail out after the first attempt.
Cheers,
A.
27-02-2014 11:49 PM
If there is no problem on plus net side then where is the problem? could it be my router blocking the access BTW I am using TP-link wdr3600 router if that's any help.
27-02-2014 11:53 PM
adw@thunderbolt:~$ ssh -l testing_connectivity freak.seedhost.eu
The authenticity of host 'freak.seedhost.eu (5.79.67.33)' can't be established.
ECDSA key fingerprint is 9f:d6:5d:48:bf:b8:a8:be:17:0b:38:3a:ac:7f:0f:f9.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'freak.seedhost.eu,5.79.67.33' (ECDSA) to the list of known hosts.
testing_connectivity@freak.seedhost.eu's password:
Permission denied, please try again.
Are you running any firewall programs (norton, mcafee, etc) locally?
