Can't connect
- Can't connect
Can't connect
11-04-2010 7:22 PM
Broadband was enabled on the 8/4/10 and have only now just got round to trying to connect but I keep getting invalid password/username error. I know my p/w is correct.. I used it to log in here.. and am using teflonmike1@plusdsl.net as my username. Suggestions/Help ?
Tef
Tef
Message 1 of 5
(905 Views)
4 REPLIES 4
Re: Can't connect
11-04-2010 7:28 PM
give Plusnet a call on
Customer Support: 0114 296 5198 or
Broadband Faults: 0114 296 5188
These numbers will get you through to Sheffield
Message 2 of 5
(418 Views)
Re: Can't connect
11-04-2010 10:17 PM
Quote from: Teflonmike1 know my p/w is correct.. I used it to log in here.. and am using teflonmike1@plusdsl.net as my username. Suggestions/Help ?
The password here can be different to the one use to access the members centre which is the one that you use in the router. Try logging on at https://portal.plus.net/index_nlp.html?home=membercentretop
Message 3 of 5
(418 Views)
Re: Can't connect
12-04-2010 1:48 AM
Thanks itsme but no, its the same p/w throughout.
dick:quote
dick:quote
Message 4 of 5
(418 Views)
Re: Can't connect
12-04-2010 1:50 AM
Quote from: Oldjim give Plusnet a call on
Thanks I'll try that..
Message 5 of 5
(418 Views)
