Can't connect to Santander online this morning.
- Re: Can't connect to Santander online this morning...
12-07-2014 10:05 AM
Any idea what's going on?, traceroute gives me the following .....
traceroute retail.santander.co.uk
traceroute to retail.santander.co.uk (193.127.210.1), 30 hops max, 60 byte packets
1 dsldevice.lan (192.168.1.254) 77.755 ms 77.444 ms 77.203 ms
2 lo0-central10.pcl-ag08.plus.net (195.166.128.189) 25.309 ms 25.086 ms 24.858 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.188) 14.100 ms 15.468 ms 15.218 ms
4 xe-9-1-0.pcl-cr01.plus.net (212.159.0.220) 13.464 ms 14.680 ms 14.449 ms
5 ae2.pcl-cr02.plus.net (195.166.129.7) 39.189 ms ae1.ptw-cr01.plus.net (195.166.129.0) 15.769 ms 33.966 ms
6 ae1.ptw-cr02.plus.net (195.166.129.2) 15.395 ms * *
7 * * *
8 * * *
9 * * *
10 * * *
etc etc etc ...
Thanks.
12-07-2014 10:16 AM
http://downforeveryoneorjustme.com
It's not just you! http://retail.santander.co.uk looks down from here.
12-07-2014 10:26 AM
That site was telling me it was up earlier and other people on banking forums are saying they can use it.
Must be in a state of flux!
12-07-2014 11:48 AM
12-07-2014 11:53 AM
http://downforeveryoneorjustme.com/retail.santander.co.uk shows it as down
People posting on the MSE banking forum say they can access it OK
I can't ping or traceroute to the site, I can access other sites fine.
The Android App doesn't connect either over my Wifi or via the mobile network.
12-07-2014 11:59 AM
That works for now
12-07-2014 12:03 PM
https://retail.santander.co.uk is up here
12-07-2014 12:09 PM
Quote from: 11110_110 https://retail.santander.co.uk/
That works for now
Not for me!, just times-out.
12-07-2014 12:24 PM
(I get 193.127.210.1 using OpenDNS)
12-07-2014 12:27 PM
12-07-2014 12:31 PM
Quote from: alanonplusnet
That's correct.
Have you tried:
http://www.santander.co.uk
Then click on "log on"?
12-07-2014 12:32 PM
12-07-2014 12:33 PM
Quote from: npr
That's correct.
Have you tried:
Yes, I get that, but clicking on "Log on" just times out.
12-07-2014 12:40 PM
Also have you cleared your browsers cache?
Does your browser allow cookie?
12-07-2014 12:40 PM
There's something odd going on somewhere, I don't *think* it's me but I can't think of anything else to check.
