Can't connect to Plus.net from BT Broadband (ADSL)
- Can't connect to Plus.net from BT Broadband (ADSL)
16-12-2014 7:49 PM
Is this normal? Is it a known problem or a BT DNS (213.120.234.6) problem? I see there was some scheduled maintenance earlier that day. It is probably in Plusnet's interests that people with BT internet can connect to you.
We turned off the Parental Control filtering but this made no difference. I could access your site without problem from a T-Mobile mobile broadband connection.
Taff
Re: Can't connect to Plus.net from BT Broadband (ADSL)
16-12-2014 11:49 PM
17-12-2014 12:27 AM
Quote from: Bob I have a BT Infinity line
17-12-2014 8:27 AM
17-12-2014 8:31 AM
17-12-2014 12:18 PM
Quote from: Bob I have a BT Infinity line and I can access the Plusnet website without difficulties
Good for you, Bob, but my client on BT ADSL can't. If I try to connect to portal.plus.net it now reports:
You're seeing this page because BT Parental Controls is active and you are attempting
to connect to a DNS server outside of our network.
You may have selected a different server in your network settings or installed an application
that uses an alternative service.
There is no DNS override. Oh well. Not really your problem.
17-12-2014 12:24 PM
17-12-2014 4:15 PM
It might not be a PN technical problem, but if BT Retail / BT Wholesale are deliberately blocking access to PN services (to inhibit supplier switching ::)) then that would be a COMMERCIAL problem for PN.
Now they would not do that would they? Just as much as BTOR never gives BT Retail preferential service over PlusNet or other ISPs.
23-12-2014 3:05 PM
Quote from: Taff
Did you ever get to the bottom of this? I tried again from home with parental controls both disabled and enabled and could access our site either way.
