Can't connect my HP Wifi printer to new router
- Can't connect my HP Wifi printer to new router
21-01-2015 8:49 AM
Just had a new router from Plusnet, but I can't get my printer to connect with it. I've got all the router details but I'm just not sure where to start. Can anyone help please?
Yours, muddled,
Jeanners
Yours, muddled,
Jeanners
Message 1 of 8
(5,702 Views)
7 REPLIES 7
Re: Can't connect my HP Wifi printer to new router
21-01-2015 9:29 AM
Which model HP printer do you have?
Message 2 of 8
(5,043 Views)
21-01-2015 9:32 AM
It's an HP Deskjet 3055A...
Message 3 of 8
(5,043 Views)
21-01-2015 9:39 AM
Hmm, according to the manual on this link the auto-wireless option is only available for 120 minutes after you first set the printer up, for reasons best known to HP. Are you able to connect it initially via USB? (you don't have to keep it connected this way, but just for setup purposes)?
Message 4 of 8
(5,043 Views)
21-01-2015 9:45 AM
Yes, I connected it with a USB cable this morning and was able to print.
Message 5 of 8
(5,043 Views)
21-01-2015 9:55 AM
OK. Have you tried the following?:
Change from a USB connection to a wireless network
1. From the computer’s start menu select All Programs or Programs, and then select HP.
2. Select HP Deskjet 3050A J611 series
3. Select Printer Setup and Software Selection.
4. Select Convert a USB connected printer to wireless. Follow the onscreen instructions.
Message 6 of 8
(5,043 Views)
21-01-2015 10:09 AM
BRILLIANT - SORTED! HAPPY HAPPY HAPPY!!!!!
MANY thanks!
J xxxx
MANY thanks!
J xxxx
Message 7 of 8
(5,043 Views)
21-01-2015 10:20 AM
You're welcome! Glad I could help
Message 8 of 8
(5,043 Views)
