Can't access website
eludlow
I can't access www.wildcataerobatics.com on my plusnet connection - other connections are fine.
Tracert is:
traceroute wildcataerobatics.com
traceroute to wildcataerobatics.com (69.90.161.230), 64 hops max, 52 byte packets
1  dsldevice.lan (192.168.1.254)  74.242 ms  99.667 ms  99.687 ms
2  lo0-central10.pcl-ag06.plus.net (195.166.128.187)  17.500 ms  24.332 ms  20.068 ms
3  link1-central10.pcl-gw01.plus.net (84.93.249.160)  15.309 ms  17.358 ms  14.192 ms
4  212.core.access.plus.net (212.159.0.212)  14.215 ms  14.069 ms  14.282 ms
5  ae1.ptw-cr01.plus.net (195.166.129.0)  14.417 ms  17.123 ms  14.425 ms
6  195.66.224.156 (195.66.224.156)  26.846 ms  14.720 ms  14.878 ms
7  * * *
8  * * *
9  * * *
Any ideas what's wrong?
Thanks!
9 REPLIES 9
Oldjim
Resting Legend
Fixes: 63
Re: Can't access website
I can access it but the tracert times out at the same hop
rhohne
Can also access site
tracert wildcataerobatics.com
Tracing route to wildcataerobatics.com [69.90.161.230]
over a maximum of 30 hops:
  1    1 ms    <1 ms    <1 ms  192.168.1.1
  2    29 ms    28 ms    33 ms  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
  3    30 ms    29 ms    28 ms  link-b-central10.ptw-gw02.plus.net [212.159.2.150]
  4    28 ms    28 ms    27 ms  te2-3.ptw-gw02.plus.net [212.159.1.58]
  5    28 ms    31 ms    28 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
  6    32 ms    28 ms    28 ms  195.66.224.156
  7    *        *        *    Request timed out.
  8    *        *        *    Request timed out.
  9    *        *        *    Request timed out.
10    *        *        *    Request timed out.
11  121 ms  121 ms  120 ms  216.187.68.161
12  120 ms  120 ms  120 ms  hp33.hostpapa.com [69.90.161.230]
Trace complete.
eludlow
Bugger. Any suggestions as to what I can do to get access?!
JamesM
I can access it, but I can't access Creative.co.uk or .com or Scan.co.uk, through Google or Bing.
ejs
Aspiring Hero
Fixes: 25
I can access all these sites:
www.creative.co.uk - Creative Events (creative.co.uk doesn't resolve)
www.creative.com - Creative Labs
www.scan.com - redirects to idealab.com
www.scan.co.uk - Scan (Computer hardware shopping)
bobpullen
Fixes: 316
Quote from: ejs
I can access all these sites ...
No problems here either. What happens when those having problems try accessing these sites? Timeout? Error message? HTTP error?
If you're having problems then what gateway are you on and what are the first couple of octets of your IP address e.g. mine is 80.229.xxx.xxx
Jaggies
http://www.isitdownrightnow.com/wildcataerobatics.com.html
Appears that "Wildcataerobatics.com is DOWN
It is not just you. The server is not responding..."
http://www.wildcataerobatics.com/  is still working for me, see screen capture below -
npr
Fixes: 9
I tried http://www.wildcataerobatics.com/ ; after seeing Jaggies post and it just timed out.
It is working again now for me.  Undecided
