Can't access swarovski.
tafkabandit
Hi all,
If I try to access the Swarovski website, it tells me access denied. It only happens when I am using plusnet and it happens across multiple devices and browsers. If I use the same devices/browsers with a 5G network it works fine.
I'm pretty sure I have seen this before with other sites but I can't remember what they were. Any ideas? My wife is getting angsty about ordering Christmas presents!
Text is...
Access Denied
You don't have permission to access "http://www.swarovski.com/" on this server.
Reference #18.74d37a5c.1700946279.104c134c
Any ideas?
Cheers, Taf
11 REPLIES 11
ghamilton123
Re: Can't access swarovski.
This isn't a issue on Plusnet, this is on swarovskis end, maybe due to a previous client.
tafkabandit
Thanks for the quick response. Can you explain what you mean?
Just to confirm... (as an example)...
Phone (chrome) -> Plusnet - > swarovski = broken
Phone (chrome) -> EE -> swarovski = working
Phone (edge) -> Plusnet - > swarovski = broken
Phone (edge) -> EE -> swarovski = working
The only thing changing is the connection. Are you saying they have banned the ip address?
Thanks.
ghamilton123
Hi @tafkabandit, some users sell their internet connection to companies to use as a "proxy", your current ip, is flagged on swarovski's end. this could be due to previous fraud on said ip, web scraping etc.
tafkabandit
That's interesting as I've had a static ip with plus net for 15+ years. Pretty sure I've never sold my ip address. Could it be malicious?
tonywalk
Check that your anti-virus software hasn’t installed a VPN. I use a VPN on my phone and with it enabled, couldn’t get on the Go Outdoors website - I was getting a permissions error
RealAleMadrid
Fixes: 64
@tafkabandit  Have you tried https://www.swarovski.com/ ? That works for me.
tafkabandit
Thanks for the suggestions but it happens on any device, not just the phone. IPad, other phone, laptop... Etc.
I tried all variations of the address, including Google searches to specific items.
I suspect it is a banned ip problem for which I guess there isn't a fix.
A year ago it was working fine because I've ordered stuff from them before.
Thanks for your help anyway.
Regards Taf.
Shep41
Seasoned Pro
Fixes: 7
Look on the bright side.
Look at all the money you'll be saving🤣🤣🤣🤣
Sorry , couldnt resist the humour
tafkabandit
Okay, so it is getting worse. We can't get on to John Lewis either now. This was definitely working last week.
Okay, I guess I need to get plus net to change my static ip?
tafkabandit
So the John Lewis site gives a different error...
ERR_HTTP2_PROTOCOL_ERROR
Same symptoms though, works with 5g doesn't work with plusnet.
ghamilton123
This doesn't seem like a Plusnet error now, it might be on the hardware dependent on config etc, or on their side, it should be working fine, reading up, you can try clearing your dns cache? I've got no clue how that might effect it, but its worth a shot.
