Can't access plus.net website or the Members Centre
GaryWilliams
Hi All,
My contract ended a week ago so I am now on the standard service.  Since then, I can't access the plus.net website, the Members Centre and some of my other suppliers online accounts.  I can't now purchase a new contract.
Can anyone help?
Gary
11 REPLIES 11
Fixes: 334
Re: Can't access plus.net website or the Members Centre
@GaryWilliams What error message (if any) do you get when trying to access these sites? Sounds strange.
GaryWilliams
Hi Jab1,
here it is:
This site can’t be reached
The connection was reset.
Try:
ERR_CONNECTION_RESET
Fixes: 334
Try rebooting your Hub. Which one is it, by the way?
GaryWilliams
Hi John,
Yes, rebooted.  It is the TP-LINK archer vr900.  I have been using this on for years.
Cheers
Gary
Fixes: 334
Very strange, Gary. The reboot hasn't solved it? Can you PM me your public IP?
Fixes: 334
@GaryWilliams Cheers for that info via PM. Now you have disabled Nord, are you able to access the sites? Note that if you try to access some UK-only ones when using a VPN, you will get the response you started this topic with, as they restrict access to non-UK IP's. Depends where you tell the VPN to say you are accessing from, and where the request gets routed.
GaryWilliams
Hi John,
I use NordVPN daily.  No problems until recently.
Thanks for your help
Gary
Fixes: 334
OK gary, but if you have disabled it at the moment, can you now access those previously inaccessible sites?
GaryWilliams
I managed to access the plusnet site having used system mechanic to optimise my internet settings,  but all other troublesome sites are still inaccessable.  If I log out of plusnet, I cant get back in unless I optimise the internet settings again.
It is all very erratic.
Cheers
Gary
Fixes: 334
OK. But are you using a VPN at the moment?
GaryWilliams
no, but the threat protection is running in the background according to resource manager.  I'm going to do some uninstalling.
Cheers
Gary
