Can someone from plusnet reset my line speed?
jcheema
Just had a BT openreach engineer round and he basically refitted a new wire and tested the speed capability on his device and it should be able to be to get around 40Mb my current line speed on my profile is 23Mb.
So hoping this can be reset.
On a different note not sure he was able to fix the wifi issue, my wifi now dies before it reaches my kitchen, before it used to go further out in the garden, he did recommend getting or asking plusnet for a new router as my one is quite old.
1 REPLY
jcheema
Re: Can someone from plusnet reset my line speed?
Never mind i rang instead reset my profile speed back up to 46Mb  Grin
End of thread
