Can someone clarify SMTP authentication for me?
memesmith
I use SMTP authenticated SMTP on my plusnet account, to send emails from outside the network on my mobile. When I switched, I also switched my wife's mailbox and for many months things seemed to work fine.
These last few days my wife has not been able to send emails. I cured the problem by turning off authentication, and read else where on this forum that authentication only works with the main account login and password, not with mailbox log-ins. But why has the problem only arisen recently?
My wife is using Entourage, on her Macbook with 10.5. and was unable to send emails even via home network. As I say  it had work for months beforehand (I think).
Fixes: 10
Re: Can someone clarify SMTP authentication for me?
It has always been the main account login and password ONLY.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 21
For sending, you only need to login to the default mailbox/account surely?
Fixes: 86
I've never known SMTP auth to work with a mailbox password so not sure why you've only recently started having problems. Don't quote me on this but I think using mailbox credentials will be an option when we move to IronPort for outbound mail.
