Can someone check my speeds please?
kinginter
This is what I have showing in my router:
Modem
Modem Status Connected
DownStream Connection Speed 14151 kbps
UpStream Connection Speed 1207 kbps
VPI 0
VCI 38
kinginter
Re: Can someone check my speeds please?
BT Speedtest:
Down 11.81
Up 1.04
Ping 24.75
That seems normal I think?
Fixes: 69
Yes, those speeds are closer to your estimate and look typical of what we'd expect you to receive.
If you do see that drop again I'd advise heading here to raise a fault: http://faults.plus.net
Adam
 Adam Walker
