Can plusnet tell me line drop statisitcs
- Re: Can plusnet tell me line drop statisitcs
19-09-2009 9:05 AM
Hi
For 4 or 5 years I had a rock steady connection. Connecting at 8128, with maximum profile 7xxx something.
Then a couple of months ago, something changed. I was getting noise on the phone line (which mostly went away), and my line speed dropped. Things seemed to improve, and I am now getting connection speeds back at 8128 consistently. However, my profile varies between low 5000's, and high 6000's - it never reaches maximum.
I suspect I am getting some line drops which is causing this.
Is it possible for plus net to show me how often I am losing connection? Or is there any other way to monitor it?
Thanks.
Thanks.
Message 1 of 9
(1,782 Views)
8 REPLIES 8
23-09-2009 7:04 AM
Can anyone look at this, now you are all back in the office?
Thanks.
Thanks.
Message 2 of 9
(679 Views)
23-09-2009 9:17 AM
I didn't see your message back on the 19th
Your connection looks relatively okay - 4 drops in the last seven days, with the current connection having been established for the last 2d23h35m.
Message 3 of 9
(679 Views)
23-09-2009 11:29 AM
James, Any movement on getting this information available on the portal?
Message 4 of 9
(679 Views)
23-09-2009 11:30 AM
None.
Message 5 of 9
(679 Views)
23-09-2009 7:28 PM
Any idea then why my profile won't go up to 8000 (not that it makes any real difference - it is just an irritation)
Cheers
Cheers
Message 6 of 9
(679 Views)
23-09-2009 8:04 PM
7150 is the highest profile.
Message 7 of 9
(679 Views)
23-09-2009 8:40 PM
I'm pretty certain my BRAS Profile used to be 8000.
Could be wrong though - it has been known
Message 8 of 9
(679 Views)
23-09-2009 8:43 PM
To get a profile of 8000 you need to sync between 9088 and 10207
Message 9 of 9
(679 Views)
