Can plusnet lock your SNR?
- Can plusnet lock your SNR?
- « Previous
- 1
- 2
- Next »
Re: Can plusnet lock your SNR?
14-02-2011 1:28 PM
Quote from: knowdice If for example you are on a long line and with a target SNR of 6dB and you get say 2mbs download sync, if you change the target SNR to 12dB then the sync speed will drop to 1mbs.
IME a target SNR increase of 3db will shave around 800kbps off your sync speed.
Message 16 of 17
(207 Views)
14-02-2011 6:29 PM
I am using a netgear 834 (not with the DGteam firmware), and I agree with the later comment that the tweak you can do with the SNR does seem to help, but it seems like there is a tug of war between what the router is trying to achieve and what the line is set to. Probably better to get mine sorted with plusnet, and do any slight tweaking with the router if I have to....... Alternatively Plusnet could encourage BT to actually fix the fault with my line so I don't need this bodge?
Perhaps I expect too much? perhaps some people would kill for an IP profile of 135K for the 3 months since joining plusnet?
Message 17 of 17
(207 Views)
- « Previous
- 1
- 2
- Next »
