Can only connect to +net's website: DNS problem?
mizkyu
weird issue I am having trouble with.
Router connects fine to plusnet, however once connected I can only access plusnet's own websites - nothing outside of them. However, this will only happen when I tell my router to get its DNS settings from plusnet. This results in the following DNS servers being used by the router:
212.159.6.9
212.159.6.10
If I try to enter alternative DNS settings, either into Windows or the router settings itself,  then nothing will resolve - I have tried the google DNS, OpenDNS, Plusnet's own recommended DNS (212.159.13.49 / 212.159.13.49)
Does anyone have any suggestions or insight? The router is a Netgear DGND3700v2 with firmware V1.1.00.15_1.00.15
I have not yet phoned plusnet as I want to skip the usual "did you try rebooting your router" (yes, a bunch of times) "computer" (yup) scripts.
thank~
EDIT: welp okay the problem seems to have decided to resolve itself now for no reason? Apparently posting on a forum asking for help was the solution, who knew Wink
Earlier today though it would literally only access Plusnet's own websites, despite all attempts to the contrary.
technology, huh
Fixes: 26
Re: Can only connect to +net's website: DNS problem?
There have been intermittent DNS issues from time to time.  May be your hit such a glitch.
Acassim
Hi mizkyu,
Are you still seeing issues with this when using our DNS servers?
mizkyu
Haven't seen any problems since Saturday - the connection seems to have been fine once everything resolved itself. It seemed particularly odd that the +net websites (including webmail etc) were working fine, but nothing else - but ho hum.
Fixes: 103
Sounds like what happens when two people have been assigned the same IP.
Fixes: 21
I know it shouldn't happen, but how does that happen Bob?
Fixes: 103
Very infrequently, most common occurrence is where routers have been shared amongst Plusnet customers
Edit: Sorry, read that as how /often/ does it happen. It can happen occasionally with dynamic IP's if there's a problem with the traffic management platform. I've only seen it a handful of times.
