Can not ping gateway/connection dropping
- Can not ping gateway/connection dropping
18-10-2017 9:52 PM
I know there's a few threads relating to this but none seem to fix my issue.
I'm using a TP link w9970, for some reason when i connect my laptop the broadband connection seems to go down, i'm presuming its to do with the router settings and not being able to ping the gateway.
Test xDSL Synchronization Pass
ATM OAM Segment Ping Pass
ATM OAM end to end Ping Pass
Test PPP Server connection Pass
Test authentication with ISP Pass
Test assigned IP address Pass
Ping default gateway Fail
Ping primary Domain Name Server Pass
Test DNS Root Pass
Network Connection Status Inspect(NCSI) Pass Diagnostics Complete
54 1970-01-01 00:01:05 PPP Warning ppp0 LCP down
55 1970-01-01 00:01:05 PPP Error ppp0 LCP down
56 1970-01-01 00:01:05 PPP Error ppp0 User request
i'm getting those errors in my system logs.
I have installed the latest firmware.
I live in a new build house and my micro filter is plugged into the only phone socket, unfortunately i don't have a phone to test the line with. can it be done from Plusnets end?
Current Rate (Kbps) 1152 9402
Max Rate (Kbps) 1144 10020
SNR Margin (dB) 5.7 3
Line Attenuation (dB) 28 44.5
Errors (Pkts) 0 0
any help would be greatly appreciated.
Re: Can not ping gateway/connection dropping
19-10-2017 3:25 PM
Does this happen with any other devices?
Is this every time you connect the laptop?
20-10-2017 12:00 AM
If you Google "error lcp down - tp link forums, you may find the information there helpful. Hope this helps
