Can my line support higher speeds?
- Re: Can my line support higher speeds?
27-08-2014 5:24 PM
Hi, I am a long time PlusNet member who has had brilliant service from day one.
I am currently on Plusnet fibre with a pro addon and I peak around 45ish down 10 or so up and I was just wondering if in the past year or so since I last checked there has been any new product releases which could up my speed?
Thanks a lot
TJ
Thanks a lot
TJ
Message 1 of 4
(602 Views)
3 REPLIES 3
27-08-2014 5:32 PM
Not that I'm aware of. My speeds are virtually identical to yours. Your only chance maybe if you're in a FTTP area & want to outlay a lot of £££££.
Message 2 of 4
(391 Views)
27-08-2014 7:03 PM
there is no product that will increase speeds, either get FTP or maybe wait for vectoring that could give a little boost if BTO ever get around to doing it instead of messing around with trials they know already works.
Message 3 of 4
(391 Views)
27-08-2014 7:29 PM
@ tjd
What are your estimates like here http://www.dslchecker.bt.com/ ?
Something that will probably be introduced next year is vectoring to remove cross talk. In the trials, 2/3 of end users saw a 25% increase in their speeds.
Message 4 of 4
(391 Views)
