Can my broadband be activated early?
- Re: Can my broadband be activated early?
21-12-2012 3:49 PM
If anyone could let me know if my broadband can be activated earlier (the earlier the better!!) then that would be great. Or who I should get in touch with to get my broadband activated early?
Thank you!
21-12-2012 3:51 PM
21-12-2012 3:58 PM
21-12-2012 4:02 PM
21-12-2012 4:03 PM
Edit: and as if by the magic of Christmas......
21-12-2012 4:10 PM
Thanks again for your reply!
21-12-2012 4:12 PM
21-12-2012 5:20 PM
Leave your router plugged in and powered on. Once the router has synched, Broadband light solid green if it's a PlusNet supplied router, call up PlusNet, tell them you have sync and ask them to activate your account early.
More often than not this works fine, sometimes BT haven't quite completed the routing work and your Internet connection won't work immediately. The only disadvantage is that you would be billed from the date it was activated even if it didn't work until the 24th.
Hope that helps.
23-12-2012 12:49 PM
24-12-2012 11:17 AM
I've just activated your account for you, the order completed around 1:47am this morning so you should be up and online shortly Hope it's all good, let us know if there's anything we can do to help.
