Can i have my upload speed uncapped please
deejayburnout
My upload speed is less than half a meg upload and i am wondering if i can get it uncapped please.
its presently at 448 kpbs.
thanks
Re: Can i have my upload speed uncapped please
Hi deejayburnout,
You're currently connected to ADSL(20CN), so to uncap your upload would come at a monthly cost(£7.83 per month), you can add this here if you wish.
deejayburnout
Oft.
I thought it was free?
not worth it for speed increase. Different if it was 1.5MB upload speed
Thanks for letting me know.
Plusnet Staff
Plusnet Staff
Fixes: 5
The uncapping of your upstream is free on 21CN products but isn't on 20CN I'm afraid.
20CN ('Up to 6Mb)
21CN Products ('Up to 16Mb')
It's always uncapped in FTTC/FTTP Products.
Chris Pettitt
Cloud Environments Engineer
deejayburnout
sorry to dig up my old thread but i have just asked for this to be uncapped at cost as i need the faster upload speed. Fibre has been delayed in my area.
Fixes: 10
Did you request that via the Max Premium link here: https://portal.plus.net/wizard/?wizard_id=20 or some other way?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
XenoGuy
Is 832kbps really the maximum upload? I sync at 888kbps normally.
Fixes: 22
It is on 20CN where only ADSL1 is available.
888k is a common upstream speed seen on interleaved 21CN ADSL2/2+ lines, some lines using interleaving and of course ones that don't can get higher upstream speeds.
XenoGuy
The reason I ask is I went to try that wizard, and told me I had to pay the £7 even when on 21CN?!
Even then, I would need more anyway to be able to stream on twitch, which, is my main reason why I'd like fibre.
Fixes: 10
You can't get Max Premium on 21CN lines, it's a 20CN feature.
Unless your upload is capped at 448kbps, on 21CN it syncs as fast as your line conditions allow.
